AMS 2.3L or RNR 2.4L stroker ?
Old Jun 8, 2005 | 05:09 PM
  #61
Jaylenospoolboy's Avatar
Originally Posted by Zeus
Has anyone confirmed that everything from the Evo will bolt up to the 4g64 block (and which one?)... bolt for bolt, hole for hole? I don't think anyone has talked about whether there are specific modifications that have to be made in order to make this block a "drop in" procedure.
I spoke with Robert at Road Race and he said they built the first RNR (don't know if they've built any others since I spoke w/ him 4 months ago). He'd be a good guy to ask.
I've heard the 4g64 blocks have head warpage issues.
Old Jun 8, 2005 | 06:44 PM
  #62
NDgsx's Avatar
Originally Posted by feldguy
Ive been reading an awful lot about this, and if you want to have the ultimate in durability and engineering, niether but if a choice were to be made, the 4g64 is it. The deck height and rod ratio is much more optimal that a stroked 4g63, and as far as the trannies go, Im not so sure the 6 speed MR tranny is as stout as the 5 speed.
You need to read an awful lot more than. The 2.3L and 2.4L USE THE EXACT SAME ROD LENGTH AND STROKE. They both have a rod ratio of 1.5, there is no difference from that standpoint.
Both engines use a 100mm stroke crank. The 4G64 has a 87mm bore.
There are two instances in which the 4G64 presents any advantage. The first would to get custom 156mm rods made and move the pin into the bottom of the oil ring. This gives you a 1.56 rod ratio and makes for a lighter piston. The second situation is if you are doing real head porting the larger bore will allow you to unshroud the valves more.
Other than that the 2.4L holds NO advantage.
Old Jun 8, 2005 | 06:46 PM
  #63
racerxl99's Avatar
Thumbs up
Originally Posted by rlazer5000
As far as a transmission for a stroker kit, either one will be fine. Even though the MR has an extra gear, the gearing on the 6-speed is pretty short so your not gonna really gain anything except for an extra overdrive gear. Neither one is stronger than the other, or so ive heard.
For stroker kits, i'd recommend the AMS kit.....they make really high-quality parts and they definitely know their stuff. Haven't heard much about the RNR stroker kit, so i couldn't give u my opinion of it. There's a video clip flying around on the boards of an EVO with an AMS stroker kit and an AMS GT35R turbo kit that is smoking cobras and LS1 camaros, so try to find that and im sure you'll be impressed! Good luck man!
two 600 whp cobras, 450+ camaro ss, and a 12 sec srt 4. all on a roll. i still have the videos. they are bad ***
Old Jun 8, 2005 | 07:55 PM
  #64
umiami80's Avatar
Does the 4G64 block have the same strength as the 4G63 block? Does it have the oil squerters? You can just swap on a Evo head?
A 2.4 would be nice, but you would really be limiting your rev range plus the vibration ona 4 banger that big may be too much.
Old Jun 8, 2005 | 11:00 PM
  #65
USP45's Avatar
I would assume that with the stroked 4G63 that you would want to run the balence shafts? Actually, if everything were balanced, why would it matter? The only thing that I could think of is the higher piston speeds exastebating an out of balance issue, but if everything is up to par then this should be a moot point.
Old Jun 9, 2005 | 12:13 PM
  #66
ShapeGSX's Avatar
Balance shafts and balancing internal engine components have absolutely nothing to do with one another.
BOOSTIN24
29
Oct 28, 2011 07:46 AM
feimax
Nov 22, 2010 11:52 PM
Thugline
Mar 18, 2006 05:57 AM
Yaroslav
60
Sep 19, 2005 05:52 PM
EVOONYOASS
19
Aug 13, 2005 08:36 PM
