Hard shift into 2nd???
Old May 8, 2005 | 06:04 PM
yellowman's Avatar
Is this common with the Evo? Every time I get on the gas from 1st, going into second is a b*^ch.
I'm afraid now that I've ruined 2nd gear. How can I tell? Just driving normally the car shifts great, but I have to be really careful @ higher speeds going into 2nd.
Would having the fluid changed make a difference?
Old May 8, 2005 | 06:38 PM
vrrrm...psss's Avatar
i have heard it is common......mine does it at high rpms, but if i pull the shifter all the way to the left when going from 1-2 it seems to help it out
Old May 8, 2005 | 07:32 PM
03BREvo8's Avatar
yeah its very common.. its just the way its built.. you can help it a lil by using some redline or bg synchroshift...
Old May 8, 2005 | 07:41 PM
blueo4's Avatar
i have the same problem!
topic discussed here over the weekend>>>>>>>
https://www.evolutionm.net/forums/sh...d.php?t=137684
https://www.evolutionm.net/forums/sh...d.php?t=137662
Old May 8, 2005 | 07:44 PM
thor's hammer's Avatar
Take it to the dealer - they have new synchros. Warrenty repair. I have to force stick into second when it's cold. Better when warm.
Old May 8, 2005 | 07:46 PM
03BREvo8's Avatar
you have to let the tranny fluid warm up and become more viscous before heavy shifting...
Old May 8, 2005 | 07:56 PM
BlueEvo04's Avatar
It helped me alot after I changed it to the B&M short shifter.
Old May 8, 2005 | 07:59 PM
03BREvo8's Avatar
you could aslo try shifter bushings....
Old May 8, 2005 | 09:14 PM
yellowman's Avatar
Thanks guys..
Old May 9, 2005 | 05:54 AM
Aluma's Avatar
mine did that too before I changed the tranny fluid. After, anytime I shift after 4K rpm it practically kicks it into second no grind...its eeeerie.
Old May 9, 2005 | 07:30 AM
GOKOU's Avatar
The dealer would probably void your warranty
raywong
40
Sep 16, 2015 03:49 PM
Thoe99
Driving Techniques
22
Dec 29, 2014 09:45 AM
ahr4156
12
Feb 21, 2012 06:57 PM
aycynokia
May 10, 2011 05:33 AM
Tsurara
Apr 14, 2005 07:10 AM
