Downpipe Question
Old May 9, 2005 | 01:47 PM
EVONation's Avatar
Downpipe Question
Okay.... I'm looking to get a down pipe that can fit the stock system without modiciation... Please note that I have heard that a lot of down pipes end up hitting or causing things to relocate. I want an easy simply install with a good performing down pipe...
ANYONE with suggestions?
Old May 9, 2005 | 01:55 PM
Compjoc's Avatar
HKS dp or Works dp
works
Old May 9, 2005 | 01:56 PM
Quickshifter's Avatar
Espelier Downpipe. Fits all Evos
http://www.roadraceengineering.com/evo.htm
Old May 9, 2005 | 01:57 PM
GNV Motorsports's Avatar
HKS downpipes always work fine. Helix works fine. I mean some like the Turboxs require putting in a spacer but i mean helix and hks work fine. Pm us if you need one.
Old May 9, 2005 | 02:02 PM
4-BNGR's Avatar
Buschur Racing 2.5" DP
Old May 9, 2005 | 02:10 PM
MTMS4's Avatar
If you're gonna keep the stock turbo and the stock cat, then a 2.5" (or thereabouts) DP seems to be the way to go. A 2.5" DP is what's fitted to the Buschur BR330 and BR350 special editions being sold through Medina Mitsubishi.
The HKS DP is also regarded as very high quality and bolts straight on (part # 3306-SM002, 65 mm = 2.56", $445 MSRP). I'm sure you can get it for less through one of the EvoM vendors.
https://www.evolutionm.net/forums/sh...light=downpipe
https://www.evolutionm.net/forums/sh...stock+cat+size
Old May 9, 2005 | 02:43 PM
Aby@MIL.SPEC's Avatar
What other mods do you have? Sorry to get off topic a bit.
People make the dp out to be a huge performance enhancer, it's really not.
I strongly suggest a cat back before a dp. I am making an assumption based on the fact that you want it to bolt up to a stock system. I am sorry if im wrong.
Old May 9, 2005 | 02:46 PM
Alias's Avatar
WORKS DP will fit perfect, at least the 70mm will, and for a plus it is ceramic coated.
Old May 9, 2005 | 02:50 PM
Thegame's Avatar
Not to ***** the thread, but will all 2.5 dp's work with a 3" hi flow or test pipe? If so than that might be the way for me to go.
Old May 9, 2005 | 02:52 PM
Alias's Avatar
The WORKS 70mm/2.75'' DP will work with a 3" HF/TP.
Old May 9, 2005 | 02:54 PM
MTMS4's Avatar
If you're going with a 3" test pipe or HFC, then I think common wisdom says to go 3" all the way i.e. get a 3" DP too; you've got nothing to lose (but probably a lot to gain).
Old May 9, 2005 | 02:57 PM
Whoosh's Avatar
David Buschur and others recommend enhancing your exhaust system from the tailpipe forward. A larger downpipe will only be choked by the restrictive system downstream. This will result in little or no gain.
Old May 9, 2005 | 03:11 PM
03BREvo8's Avatar
buschur 3"
Madsta
Mar 21, 2016 09:01 AM
Xvolution
Dec 5, 2014 07:34 PM
helgusmc
Dec 7, 2010 05:05 PM
XxLaNcErGTSxX
10
Aug 10, 2009 02:57 AM
nala
Feb 1, 2009 08:05 AM
