disconnected ebc and got 20psi..is it normal?
I have a Blitz ebc and when I just unplugged the electric wires(not solenoid)Im still getting 20psi from my boost guage. Is this normal?
sounds like the controller was set at 20 and you unplugged it and you are getting whatever flow the solenoid is letting through. Just so happens you are getting 20.
Plug it in, turn it down. Unplug it and see if the boost changes. I think the difference is your unplugging it.
[QUOTE=timzcat]sounds like the controller was set at 20 and you unplugged it and you are getting whatever flow the solenoid is letting through. Just so happens you are getting 20.
QUOTE]
I think that may be the cause. I just unplugged the head unit to have it taken out to custom match the stock panels by the shop. It was set at 20 psi before I unplugged it.
QUOTE]
it's ebc, not mbc.
you still have your restrictor pill. 20psi is normal, since stock boost is at 19.5 psi.
depended on the weather, you'll boost up to 23psi then taper to 16psi.
usually 20psi, and down to 17psi.
