Car stalls when giving slight gas on an incline..
Old May 13, 2005 | 10:54 PM
BOOSTEZ's Avatar
All:
I've had this problem since I had the car and I've since then added a intake system on the car. Now of the numerous hiccups the car actually shut off on one occurence. Here's the symptoms:
If you are backing out (or going forward) of a garage and you give it slight gas and let out on the clutch a little bit, then push the clutch back in quickly and you are on an incline, the car will stall. I've narrowed it down to it only doing this when the coolant fan comes on. Somehow, something is causing it to stall. It's intermittant even when the fan is on. It won't do it all the time.
Has anyone else had this problem?
-M
Old May 13, 2005 | 10:58 PM
plokivos's Avatar
dry sump oil system... need it.
Old May 13, 2005 | 11:11 PM
BOOSTEZ's Avatar
What is that? And what does that have to do with the stalls?
-M
Old May 13, 2005 | 11:33 PM
plokivos's Avatar
sorry, you're just getting lean spots below 3400 rpm because of your intake isn't tuned.
intake gives you lean spots or leans out at idle or start.
your stoich level is gone.
it's either that or you're running too rich.
Old May 14, 2005 | 12:26 AM
BOOSTEZ's Avatar
Uh.. not with hardly no load on the car (remember I'm actually parking)....
It may have something to do with the MAF sensor.. I'm not sure.. but it doens't happen in normal stop-n-go traffic. And the fan coming on is a must to reproduce the problem. This leads me to believe it's something else.
-M
Old May 14, 2005 | 08:38 AM
Ev0 1's Avatar
Did you ever get the recall on the fan controller?
Old May 14, 2005 | 09:31 PM
BOOSTEZ's Avatar
Nope, no recall on that one. I just checked my car for recalls and they said I have no outstanding recalls to date..
-M
Old May 14, 2005 | 09:38 PM
bdking57's Avatar
I had this problem..It was the BOV causing it. put the stocker back in plus i changed the plugs and it completely stopped. I couldnt tell you which was the fix though.
Old May 14, 2005 | 09:48 PM
BOOSTEZ's Avatar
Hmm.. what's funny is that I had this problem when I had the stock intake system on the car!
I have the 1G BOV now and I doubt that's leaking. If it was the BOV, it would do it all the time and not just on an incline. I wonder if the MAF has to be leveled properly. Hmm...
-M
Chris725
Nov 24, 2015 06:40 AM
BOOSTEZ
Oct 8, 2007 09:45 PM
ripnet
Sep 20, 2006 01:42 PM
ArchieBabes
Feb 23, 2006 08:42 AM
BOOSTEZ
14
Jan 11, 2006 02:21 PM
