View Poll Results: Do You believe it?
YEs
75
26.22%
No
211
73.78%
Voters: 286. You may not vote on this poll
469AWHP on STOCK TURBO!
Originally Posted by EVIL_EVO_VIII
I know u have a 6 speed. I think scott made a 5th gear pull if im not mistaken and ended with like 401 or something close to that. Dont know what he made with previous pulls! I just made a suggestion for next time, just for the hell of it to see if u also get some gains!L8r!
Bottom line is-
Upon request of the dynosheet was placed, still are "some" that has some disbelief of the outstanding outcome of my brother's achievement.
Numbers are there, let's take the lowest one shall we? 434AWHP !!!!! on a stock turbo? GEEZ that is comparable to a healthy BPU Supra (BPU=Basic Performance Upgrades and stock twins) and is a 6-cil.
His EVO will be at the track here locally by August racing NHRA. I challenge ANY of you that run awesome times on "freezing" weather to come down to SUNNY, HUMID, HOT as a BBQ to come and run good times. Who runs good here runs good ANYWHERE in the US.
Still ran a 11.6 and still room for improvement. Better times to come, stay tuned.
Jesus
Jesus
Originally Posted by 1BADASSEVO8
So you are saying that taking off the filter lid will gain 7-13 WHP more.
He talks and argues everything in the posts. Questions facts and everything else. Yet, don't know the answer to the above simple and elementary question and want us to give the answer.
I have a dyno chart, Mr. BADASSEVO8. With the box cover on and with it off. Do you need to see it. I will be glad to post it for you. Is nice to know people with this kinds of answers, right? I got one with a BOV on and off, with Cams on and off, in pump gas and race gas, with flash, with out it, etc. Which other do you want? I am sure between all of us here we can find the perfect chart for you!
Not sure why the lid off would work better only in Orlando, but it's definitely not the way to go for most people. People don't gain that much hp with ANY intake, much less just from causing the air to be hot and turbulent by removing the lid. Scott, you know that doesn't make any sense...
I been reading some of your posts. Seems you allways have an excusse. Hit the rev limiter, timing was off, bad 60 ft. shifted short in forth gear, 4th in the MR limited my trap speed, etc.
Come on man! Also, seems you are the best at everything you do. I don't know how you do it pal. Congratultions. You are a master in your game!
Jesus, I have shown respect and given props to you and your brother for your accomplishments and driving ability. 430whp in the stock turbo is of course a great accomplishment, but the title of this thread says 469whp. That is quite a big difference and can be explained by the "4th gear issue" on that Aerocomp dyno. The whole point of the argument that ensued was that these high-gear readings everyone in Orlando is getting are incredibly inflated and should not be claimed publicly. Miguel was the best example, because he was claiming 357whp (4th gear) when his true whp was only 307 (3rd gear), which was obvious when looking at his minimal mods. All we ask is that claims are made based on the proper numbers, not some inflated numbers caused by dyno'ing in the wrong gear on a Mustang dyno that has been set to mimic a Dynojet.
Explain why you think I am wrong. You seen the charts. Take 327 whp {Mustang}, add 18 percent to read a dynojet, you get 385. What is it that does not meke sence to you? The facts are there! Do the math. What is the matter with you. The horse is dead!
Originally Posted by 04AWDTURBOEVO
Here is another one. Probably never tried the trick, but yet feels it does not make any sence. I let you in a little clue. 1G and 2G DSM's all run intakes with the same Vortex Type Sensor and open intakes. Under hood hot air, and turbulence have never been a factor. Why would it be different in an Evo. My Talon was fine. My Eclipse was fine. Now my Evo is fine.
Originally Posted by dsm95hybrid
I have not been back to the strip in a while. I think it is a substantial hurdle to figure out the 4th-5th gear deal prior to returning. There is a mph theory on MR gearing that I have already mentioned. 5th gear is fast as hell, but you are only in it for like 80 feet, hardly long enough for HP to shine.
1st
, 2nd
, 3rd
, 4th
Dude, I posted my dyno sheets in the other, now vanished thread. I gived you a dyno chart from another Mustang dyno, in Mustang mode. Then posted a second sheet in the Aerocomp dyno, in the Jet mode. Difference between them was 18% which is what is supposed to be. How do I have to spell it for you.
He should have about as much HP as TQ which would make sense at the 310 range. 5pd Evo's should dyno in 3rd. MR's in 4th.
Originally Posted by Geo@EvoStore
Miguel you do not have 357. You know that. You know that earlier in the day before any of you guys dynoed I told you 4th gear had some weird issues to go by the third gear number. 307 is right for your mods. Be happy. That is good power for little mods.
I am putting out 405whp on a dyno dynamics for reference. This is with race fuel and 26pounds of boost on a gt35r though. Those are good times for the stock turbo. It also shows that with a 120 trap speed I should be more around 11.4ish I will eventually get there
Oh and in Phoenix I trapped 121.xx which is 1400ft. So at sea level I would probably be more like 122 or so.
Correct including that Pensacola evo that dynoed like 589 in third gear then jumped to like 638 in fourth.
Originally Posted by Evolving-04
I dynoed 601@30psi at AMS at then at aerocomp I dynoed 638@35psi so you mean to tell me that another 5psi is not good for a 37hp gain because I always heard it was like 1psi equals 5-10hp and that would be 7hp per psi for me? Everyone there said it looked like it smoked the tires in third so that might be why it was lower in third? Jesus and those guys have there stuff together so I have no doughts about there equipment and also I know AMS would not benifit from making false claims (not to mention all the 600+hp evos they have had in magazines) and how do you explain my race with the s/c zo6 which dynoed 644hp because we sure were running pretty close together?
The claim here is that the change from 3rd to 4th gear on that Aerocomp dyno is totally bogus. You know there was no "smoking of tires" in 3rd gear. That dyno adds like 40-50whp to cars just by going to the next gear. No one is saying you aren't making mad power...we are just saying that Aerocomp dyno gives inflated numbers in 4th gear on a 5 spd. That is, unless you believe that the 03 with TBE, MBC, flash w/10.7 AFR, no cams, 93oct actually dyno'd 357whp (4th gear) instead of 307whp (3rd gear).
You know that dyno numbers aren't transferrable. Numbers at AMS's dyno won't be the same at other dynos, and wherever the Vette dyno'd won't be the same elsewhere either.
I have seen a 600whp 4g63 spin those rollers when the facility first opened. The car tried to jump right off the dyno.
If Buschur can smoke the tires on the dyno with 393whp, I'm sure Chris can break them loose with 600whp.
Scott, you should really change your name to Red Herring. You focus on the unimportant aspect of a point being made instead of the underlying truth, which is that "smoking" the tires in 3rd was not why he suddenly gained 50whp by switching to 4th. We've already established the fact that moving up to 4th from 3rd on a 5spd on this dyno results in inflated numbers that aren't factual. That is, unless someone here still thinks Miguel legitimately made 357awhp with no cams on 93oct and a rich tune on that same dyno in 4th gear...
