View Poll Results: Do You believe it?
YEs
75
26.22%
No
211
73.78%
Voters: 286. You may not vote on this poll
469AWHP on STOCK TURBO!
I'm not sold on the mph difference being that great. You got just about 112mph with your 313/312, but it would take 350-370whp for a 5spd to hit 115-117. I am guessing your dyno run was also in 3rd or 4th gear showing the proper whp. I also highly doubt I'm making more whp than you, so 310-315 sounds about right for me, too. Oh, why does your sig say 400+ hp/tq? Are those adjusted crank values based on a 25% drivetrain loss?
As for Miguel, you say you are not making less than he is, but you said yourself that he got 357whp. How does that measure up? I still believe his 307whp in 3rd gear is much more accurate.
? The target is always moving.It says whp doesn't it?
I don't know where I said anything about someone having 357whp. You'll have to show me. I don't typically talk about other people's cars.
Originally Posted by dsm95hybrid
Who says I have/had 313whp on that run
I had to assume you had 313whp on that run, because 313whp is the proper horsepower for that mph. You know I ran right at 111, but couldn't get over it due to my rev limiter and that I was bouncing off the limiter 4-5 times before hitting the traps. That would indicate I can hit 111 at least, and _maybe_ close to 112. That's still only ~320whp, so it would be reasonable to assume that you were in the same range when you did your last run, right? It would make no sense for you to run 12.26@111.6 with anything more than 320whp. Even if you were gear limited in 4th, your 1/8th-mile ET/MPH were no faster than mine either, so it's not like you were making more power, especially considering we appear to drive with just about the same skill.
Originally Posted by BoostedJoe
he did 307whp in 3rd gear then like 342 whp in 4th , Then he removed the stock air box cover and did 357whp!
You're right, it was Joe (sorry). So, if you believe your dyno numbers and Joe's dyno numbers, then you have to believe that Miguel's numbers. 357whp is way, WAY more than he is capable of with those mods on 93oct on a vanilla flash with 10.7 AFRs. You and I both know this to be true...
At the least, we have all rolled the same dyno so there is a perspective. 90% of the rest of the well known Evo community spins a DJ so this should be an equal comparison. The "Chris" AMS Evo just spun this dyno a week or so prior so this is a safe benchmark. 668 w/ a 50 shot is on par with what it put down elsewhere if you deduct the nO2.
Originally Posted by EVIL_EVO_VIII
Scott, i got on the dyno later that day. I made 307 3rd gear pull. Then 341 in 4th with the air box cover in, and made 357 in 4th with the top of the box off!! Warrtalon u have to understand that 4th gears makes more boost and holds it longer, in 3rd i was boosting like 19psi and 4th it was spiking to like 23 and holding about 20.5 to 21 towards redline. Yes the car has alot more room for improvement! Ask Boosted joe, he seen me race 109-110 cars a few times! Warrtalon also 5 speed with trap higher than a 6 speed like scott said bc of gear ratios! I will post dyno sheet when i get a chance!
Miguel's car was one of the stronger ones stock. So if there is a +/-20whp variance, then it is understandable. I don't know anything about his flash though. I believe he has an O2 housing. I don't.
+/- 20 maybe, but not +50. You haven't touched on your whp relative to your et/mph still. You do agree that I am probably putting down no more than 320whp with my 104/93oct fuel mix, right? And that would mean you were putting down no more than 320-325whp on your best run. Lastly, that would mean Miguel could run at least 115mph in the 1/4...I keep going back to this without getting any feedback.
Originally Posted by Geo@EvoStore
Miguel you do not have 357. You know that. You know that earlier in the day before any of you guys dynoed I told you 4th gear had some weird issues to go by the third gear number. 307 is right for your mods. Be happy. That is good power for little mods.
No warrtalon, you have more than the 325 range on a DJ type reading.
I have not been back to the strip in a while. I think it is a substantial hurdle to figure out the 4th-5th gear deal prior to returning. There is a mph theory on MR gearing that I have already mentioned. 5th gear is fast as hell, but you are only in it for like 80 feet, hardly long enough for HP to shine.
Originally Posted by Knyght
Swap some smaller height tires on there, and should be able to get into 5th sooner right?
Anyhow let's get this thread back on topic...
