when does fuel cut come into play
Originally Posted by steelcityevo8
does anybody know at what boost level does the computer throw in the fuel cut
Fuel cut occurs at 1700 Hz Karman value at 20°C and 1000 mbar athmospheric pressure approx. That is roughly 1.2 bars relative boost. Therefore FC is dependent upon boost pressure, outside temperature and pressure and the amount of air you are sucking into the MAF.
Moving to tech..
Speedlimit...
Moving to tech..
Speedlimit...
Moving to tech..
Speedlimit...
yeah im lowerin boost cause i dont want to keep tightning up the bov cause it seemed when i had it real tight it caused some compressor surge at part throttle when boost would be building. so i soften up the bov cause of that situation and i dont think its the bov opening up too soon cause i had same problem happen to me with the bov tight as hell
