Patient Mr. White Rabbit on operating table
Old Jul 14, 2005 | 03:28 PM
DynoFlash's Avatar
I can not contain my excitement as a customer has shown up with a 2004 Evo with the White Rabbit Turbo just now for a tune
He was previously at another tuning house recently and made fairly weak power - 312 whp max
His mods are
Cone filter intake - (generic)
Walbro pump
660 Denso Injector
Greddy BOV
3" Exhuast
Hallman mbc
Stock cams and fmic
Reflash
Soon I will have his base line dyno sheet
Old Jul 14, 2005 | 03:29 PM
tke_413's Avatar
Hahaaaa, what everybody has been asking for!
Old Jul 14, 2005 | 03:32 PM
rook's Avatar
Great news Al There are hundreds of people waiting for more numbers. Put the rabbitt through the ringer and post up some results.
Old Jul 14, 2005 | 03:41 PM
titaniumkingpin's Avatar
YES!
is this running pump with no alky?
Old Jul 14, 2005 | 03:43 PM
evovette's Avatar
If this turbo comes out with 420 or more WHP Im ripping mine off and sending it to FP
Old Jul 14, 2005 | 03:47 PM
954DRGSR's Avatar
I would settle for anything over 35 more whp on pump w/ stockish spool. It would be worth it to me then. That's about the increase I get with my race gas map.
Old Jul 14, 2005 | 03:55 PM
Why?, what is your expierence with this turbo?
Old Jul 14, 2005 | 03:58 PM
evovette's Avatar
I have none, but after making 355 hp with my stock turbo on 93 and no alky Id like to see 420 plus HP or else for me personally it isnt worth it
Old Jul 14, 2005 | 03:59 PM
954DRGSR's Avatar
355 whp on 93 oct is impressive. What are your mods and what type of Dyno?
Old Jul 14, 2005 | 04:03 PM
evovette's Avatar
HKS RS intake, GSC staggerd cam , helix ic pipes, Turbosmart BOV (recirc only) Nisei IC BR TBE(3") and a liberated cat, walbro FP and it was 335 HP not 355. hit the wrong button, sorry for that.....and a manual boost controller set @23 psi
Old Jul 14, 2005 | 04:04 PM
evovette's Avatar
O and it was at Pruvens Dynojet so at least it will be on the same dyno
Old Jul 14, 2005 | 04:05 PM
DynoFlash's Avatar
Sorry to disappoint you guys but i have no conclusion for you yet - only more data
Basically the car was running 23 psi and it was tuned fairly well
The a/f and ignition timing was spot on
I saw NO NEED to retune as I can not in good faith take money from someone to tune a car that is already tuned in the ball park
The car was tuned on 93 octane with 23 psi of boost falling slightly to 21
The results on this car are poor. The customer is very disatisfied with the power he is making.
I suggest a boost leak test and compresion test to see if his car is healthy. The mechanics here are all leaving for the day so we can not go further with this car today.
This dyno test can draw no conclusions about the turbo as the car may have boost leaks and it may have a bad engine.
All i can say is the power is low.
JUST TO BE CLEAR - I did NOT tune this car - it has the flash tune from another tuner still in it - we DID NOT touch the boost controller - we dynoed it as it left the other tuner
Old Jul 14, 2005 | 04:08 PM
keep us updated please
Old Jul 14, 2005 | 04:12 PM
Vroompsh's Avatar
i wouldnt call 312 whp weak at all with those mods
Old Jul 14, 2005 | 04:27 PM
QAT-R's Avatar
312 whp is weak but if this is the car that TT had trouble flashing, I recall he had some ignition issues. Zeus is dynoing in a couple of days so we will see. I hope this thing doesn't flop.
