Flashed White Rabbits: Please post your numbers Here!!
Old Jul 17, 2005 | 07:39 AM
  #136
Precision Dyno's Avatar
Originally Posted by davidbuschur
Hmmm, very interesting reading.
I'm so glad that I posted all the actual results of our testing of our own 21g as the development went on.
Also very glad I didn't just start selling the turbos because we invested tens of thousands of dollars in getting the wheels and such made.
I don't know what the deal is or why the results are varying so much from what was said it could do.
What I am seeing from most of these runs is about the same results I saw from our 21g wheel. More power but it was marginal, marginal can make you money but will mostly just **** people off and put doubt in other peoples minds.
The heat I took for being slow to release the 21g and the failures I posted along the way now don't seem so meaningful to me.
I am still waiting for another wheel to test, if and when it works I'll be selling them, but as always, I won't sell anything until I am sure it is going to produce what it should.
David Buschur
www.buschurracing.com
This is why you have been the most respected vendor in this and the dsm community for so long.
Old Jul 17, 2005 | 07:46 AM
  #137
Richard Sierra's Avatar
Originally Posted by BadazzCR
Got a chance to test another WR turbo. This car has similar mods as the other one tested. We never got a chance to run it on racegas but did do some pump gas tunes. The car has 3" turbo back, intercooler piping, hks 272's, aem ems, intake pipe with out maf.
Run# 14 is the stock 03 turbo
Run #10 is the WR turbo
I was suprised to see power gains on pumpgas, after the last WR turbo. I asked the customer if he wanted to run some racegas through it just for comparison's sake but the customer declined. I am starting to wonder maybe not all the WR turbo's are created equal.... guess time will tell.
IIRC, the wheel is machined. Is it possible that minor variation in the machining process is causing the difference?
Old Jul 17, 2005 | 08:00 AM
  #138
jj_008's Avatar
I 'm believing this maybe the problem....
Old Jul 17, 2005 | 08:15 AM
  #139
sleet's Avatar
David Buschur
That is how it should be.
Old Jul 17, 2005 | 08:24 AM
  #140
MalibuJack's Avatar
Originally Posted by joeycoates
I have thought about that as well, but your GT3076 is a different animal, it may be using a wastegate that does not require the same amount of pressure to keep it closed. Basically the stock solenoid might not be capable of exerting enough pressure on the stock WG actuator to keep the WG from opening at high boost, the ECU is trying to tell the actuator to keep it closed, but it does not have the mechanical strength to do so. There are too many reasons to list as to why this may be, but I just went and read a thread that MalibuJack wrote which in essence said that he has been able to maintain a higher boost level on his stock turbo be utilising the GM boost solenoid which I guess allows more pressure to the WG actuator thus keeping it closed. I think that ha said the GM solenoid can be had for $30 and he has a way to install with no splicing. I have already requested instructions on how to integrate, for $30-$50 it could not hurt....
Also MalibuJack is currently using the 2005 10.5 hotside which supposedly flows better the the older 10.5's and 9.8's, possibly due to more surface area to flow through. Would more surface area also mean that the WG actuator has a harder time keeping it closed as ther is more to push against? The WR uses the 05 10.5 hotside.....
Just wanted to clarify a few things, because I didn't document this very well (Kinda kept a few secrets.. sorry guys)
My 10.5 housing is an EARLY housing, the actual flow potential of both housings is identical from new to old, where the new housing is better is by siamesing the two ports together, you have a merged flow which results in less turbulence which should result in improved flow out of the O2 housing, this is the one and only benefit of using a stainless O2 housing over the stock O2 housing is the chamber is bigger that its not as affected by it.
My compressor cover is a 2005 JDM Evolution MR cover, its casting is ever so slightly different and its scroll chamber size is marginally larger (nothing worth mentioning that would be worth any real power gains). The turbo on my car is a STOCK '03 CHRA with these components, I have another TME turbo with these components and other secret sauce that I have been sitting on waiting on results of this turbo.
The GM BCS is installed in a manner identical to how you would install an MBC, as Al (Dynoflash) stated, the stock BCS system is a bleed system, when the boost levels go higher than what is designed, you have restrictors and a bleed valve (your stock solenoid) The restrictor at the boost source is basically like setting an MBC for 17psi, the second restictor at your solenoid sets the 19.5psi setting, the solenoid just allows the air to bleed through that second restrictor. Vacuum line size and restrictor size will affect how well the system works, altering the location of your vacuum/boost source, the restrictors, will affect how this system works. WHen you begin using higher boost levels, you get more pressure in those lines and at a certain level, the bleed system just can't bleed off any more pressure and the boost begins to taper. The Vishnu boost tube, and the UTEC's adjustable ABC are both supplimental bleed vents, which will raise your boost a little more, unfortunately its still a bleed system which can become overrun. Additionally, utilizing the stock BCS system but altering the restrictors or bleed system, increases or decreases the level where your boost control happens, but doesn't in any way help the range you have to work with by very much.
A restrictor system like a MBC or closed loop EBC, basically closes off the flow to the actuator until a preset level is set, then it opens it and allows the actuator to open. The spring pressure inf the actuator, and the preload are what keeps the flapper closed.. ANY MISADJUSTMENT WILL RESULT IN POOR PERFORMANCE, too tight and it'll spike then taper, too loose and it'll never give you your desired boost levels...
What does all this mean? You need to verify the preload of your wastegate, and you need to have more control than what the stock BCS can offer if you want good results.
If you have a stock ECU with a reflash, you NEED AN MBC or EBC.. If you have an EM unit that can control the stock solenoid YOU NEED TO UPGRADE TO A PERRIN or GM BCS..
Now back to your regularly scheduled program...
Old Jul 17, 2005 | 08:34 AM
  #141
RoundPro's Avatar
Here are my feedbacks on the WR turbo:
Replaced my TME turbo with the FP WR and Gained 1.2sec. at MSR.
To me, that's a huge improvement!
Old Jul 17, 2005 | 08:35 AM
  #142
evolved4g63's Avatar
This is off topic but interesting. Just wante to let you guys know there is already a used WR turbo for sale in the private f/s section. Only has 100 miles on it. There is also a 50 trim kit for 150 bucks more
Old Jul 17, 2005 | 08:37 AM
  #143
DynoFlash's Avatar
this is a drivers turbo. this is a turbo for people that want fast spool, a mean responsive turbo that can kick *** in on tight courses AND hold some ground on high speed courses. this isn't the OH i'll slap on a gt35r and gain 100 hp. no... no no no no NO. this is NOT THAT. so don't look at it like that... yer gonna hurt its feelings
Originally Posted by trinydex
dude... what is wrong with the last numbers that were posted... 360 is pretty damn close to 370. and what you guys aren't even considering is that in the same car on teh same dyno there will be deviations from run to run. there are no REPEATED runs here... NO standard deviations... if you were scientists you'd get executed. and the peanut gallery would burn the hell of 1000 nuclear warheads.
doesn't hold boost... so that's the the turbos fault AUTOMATICALLY? when i get on the dyno and say my stock evo doesn't hold boost... what the does the world of evom tell me? 10 trillion things the turbo only being ONE of them. try the bov... try the stock boost solenoid, try leaks in your pipes, try ANYTHING cuz **** man... the car and the support of the turbo don't like holdin' all that gas in.
and why are you all expecting so ****in' much? it's marginally better than the tme, that's GOOD. if you don't wanna pay 1500 for that... then **** off. if you already paid 1500 for it then you shoulda thot a little harder. i'll come out and say it first cuz no one else has the nuts for it.
this is a drivers turbo. this is a turbo for people that want fast spool, a mean responsive turbo that can kick *** in on tight courses AND hold some ground on high speed courses. this isn't the OH i'll slap on a gt35r and gain 100 hp. no... no no no no NO. this is NOT THAT. so don't look at it like that... yer gonna hurt its feelings.
"A drivers turbo eh"?
Kind of like the emperor's new clothes?
What does that have to do with the 441 whp cpacity which was claimed on a evo with no cams and stock intake ?
  #144
MalibuJack's Avatar
Very very offtopic.. But the WR turbo will require nothing more than gaskets and studs for an install, the 50 trim will require $1000 or more in parts to install it, plus a custom O2 housing and/or downpipe and lower intercooler pipe.
Please we need to keep these offtopic posts to a minimum..
Old Jul 17, 2005 | 08:38 AM
  #145
DynoFlash's Avatar
Originally Posted by altrix99
The point is, if it was said in the very beginning, it would be fine... But it wasn't, Switzer's 440+whp dyno and mention of competing against medium frame GT series turbos were mentioned. If there was information given out (its said to flow 48lbs/min or so which puts it in 50 trim territory, but I'm suspecting more like 44lbs/min) then ppl could make a more educated decision. But all you got from its producer and their affiliates were 'WHITE RABBIT OMG, 440whp, STOCK SPOOL!". Lots of hype and IMO, misleading unethical biz.
I concur 100% with your take on this
Old Jul 17, 2005 | 08:43 AM
  #146
MalibuJack's Avatar
I didn't want to say anything earlier about this turbo because I really want to see results.. But the one thing that I saw on the WR turbo was no attention was paid to the EXDUCER AREA of the casting, The slot, chamber (where the boost accumulates), and the discharge, and the DISCHARGE TUBE TO THE INTERCOOLER are still the same, this to me could restrict its potential efficiency and flow.. I'd like to see one with the chamber and discharge enlarged slightly, more efficiency would result in more dense air at slightly lower boost, but only if it can get out of the turbo, otherwise you just heat the air more at the compressor wheel and transfer slot.. <edited for typos>
Old Jul 17, 2005 | 08:52 AM
  #147
Sorry, but the kit includes all ot the above.
Old Jul 17, 2005 | 08:54 AM
  #148
MalibuJack's Avatar
pm Me the link, I stand corrected if the kit came complete with the manifold, wastegate, and all the parts needed for install.
Old Jul 17, 2005 | 09:00 AM
  #149
MalibuJack's Avatar
and in reality, if you can maintain boost pressure within the turbo's efficiency through a higher RPM, where your able maintain torque through a higher RPM, you can in theory produce those horsepower numbers, but I see some efficiency things that customer cars may be lacking that the Swytzer car had.. Boost control and leaks being one, the stock MAF being another, the ignition system is a much bigger contributor than many people actually realize also.
Old Jul 17, 2005 | 09:09 AM
  #150
KazzEvo8's Avatar
For those concerned about boost taper WORKS seems to handle it well with their flashes as evidenced by posts here: https://www.evolutionm.net/forums/sh...hreadid=144301
