BG Syncroshift I & BG Syncroshift II
Old Jul 15, 2005 | 11:11 PM
memo3's Avatar
I did some search but couldn't really come up with differences except that BG I being non synthetic and BG II being synthetic.
I just put some BG Syncroshift I into my transmission but i need to add little bit more (I am talking about less than half quart). My local stores didn't have the Syncroshift I in stock, so adding the the II will make it worst?
Also besides everything, Can BG Syncroshift II be used on our Evos? It says on the BG Syncroshift II "For Modern transmissions" instead of saying For Front Wheel Drive Transmissions like on BG Syncroshift I.
Memo
Old Jul 16, 2005 | 09:19 AM
DaWorstPlaya's Avatar
Good question, I've been trying to find out too ... does it say anything on the labels on the containers ... eg: the weight of the oils (eg: 75W-90) or the GL rating (eg: GL-S or GL-4 or GL-5) ??? Let us know ...
Old Jul 18, 2005 | 07:45 PM
mdosu's Avatar
Bump!!!!!!!!!
can someone help us out on this question here please???
I'm buying BG Syncroshift very soon and I'm stuck on which to buy!
thanks!
Old Jul 19, 2005 | 02:36 AM
memo3's Avatar
bumpy
Old Jul 19, 2005 | 06:04 AM
marksae's Avatar
I talked to RRE about this a while back. While BG I is okay to mix with other fluids, they don't recommend mixing BG II with anything.
Searches will tell you to use BG I over BG II saying II is too slippery, but the people claiming that don't seem to have tried it themselves.
Personally, I bought 3 quarts of BG II and it's still sitting on my shelf because I ended up using Synchromesh. I may end up trying the BG II next.
Old Jul 19, 2005 | 11:10 AM
mdosu's Avatar
1. so 100% BGII - no mix - should be good?
2. where's the cheapest place I can get this stuff in 1.5 weeks.
Old Jul 19, 2005 | 11:18 AM
QAT-R's Avatar
Probably Lancershop. I just use the Pennzoil synchromesh stuff from autozone, same as BG and GM, just a lot cheaper and readily available.
Old Jul 19, 2005 | 11:22 AM
titaniumkingpin's Avatar
i did not have good luck with the pennzoil synchromesh. my car wouldn't like to go into 1st easily.
Old Jul 19, 2005 | 03:10 PM
mdosu's Avatar
okay, I found it at Lancershop. Does anyone know how big 1 container is? How much fluid is in one?
Old Jul 19, 2005 | 03:18 PM
wthoevo8's Avatar
I think the container is one quart, you'll need three. The price on lancershop.com is about $38. for three quarts. your tranny will need 2.7 quarts, if I can remember correctly.
Old Jul 19, 2005 | 03:23 PM
sr20det91's Avatar
^^^^^^ I believe they are one quart each.
On a side note I have used BG I and BG II, as well as giving the syncromesh a try.
IMO ...both BG products performed better. With BG I being the best of all that I have tried.
The syncromesh seemed great at first, but seemed to break down rather quikly with shifting becoming pretty notchy after only a couple thousand miles.
I then tried the BG II which was fine for normal daily driving but I would always miss gears when shifting near redling. I believe this was due to the fact that the oil was so good it was not allowing the syncros time to do their job between high RPM shifts.
I currently have the BG I in there and have had it for about the past 10k miles without a missed shift and much decreased decel noise. I love how the tranny feels with it and will probably use it exclusively from now on.
Old Jul 19, 2005 | 05:12 PM
mdosu's Avatar
oh okay, I knew there was a reason they showed 3 together...so $38 for 3, okay I'm buying now. thanks!
KartaRailed
35
Apr 30, 2010 12:47 AM
dee_yamaha
Mid-Atlantic Region
Apr 12, 2007 06:48 PM
thestaton
For Sale - Cars For Sale
12
Dec 7, 2005 05:48 AM
Derekj03
Jun 12, 2005 08:25 PM
OX
Feb 5, 2004 01:10 PM
