japan and blow off valves
Old Jul 21, 2005 | 09:55 AM
  #31
Evo007's Avatar
Originally Posted by savageevo
what I have been told, new emanage. has datalog, set a/f ratio and do a couple passes and computer will try to get a/f setpoint. similar to exede. it uses wide band to do this. capable of removing airflow meter at the filter for higher hp cars similar to aem. uses actual crank angle sensor not feedback from oem computer to control timing and injectors. does not use oem injector signal like old emanage. will control timing and injectors not just bypass and send different signal. what I was told, will do just as much and more as stand alone and still have the drivability as oem. what I have read, others with full stand alone like the aem are haveing problems as soon as weather changes. with this set up you have all the features of stand alone and still have drivabitlity as oem.
That sounds like something to check into!
Old Jul 21, 2005 | 10:38 AM
  #32
Ludikraut's Avatar
... sounds to me like the Grenade Fairy is coming to SoCal in the desert soon...
l8r)
Old Jul 21, 2005 | 08:02 PM
  #33
savageevo's Avatar
i have the pics but how do I up load. help, thanks.
Old Jul 23, 2005 | 12:00 AM
  #34
savageevo's Avatar
bump. anybody help with pics?
Old Jul 23, 2005 | 07:38 AM
  #35
Z1 Performance's Avatar
not exactly - it is modifying pulsewidth of the injector, but not setting the initial TOG - so the stock ecu is still very much in the show. For the amount that this costs, and the needs most Evo owners have, the flash is still the preferred method IMHO. I don't know enough about the new SMART system to comment, but definitely sounds interesting as well
Erik Mio
Member Unresolved Disputes
Nov 3, 2016 06:44 PM
sideway180sx
Mar 25, 2013 06:31 PM
dolemite45
Apr 20, 2005 10:35 PM
ex-honda
27
Oct 29, 2003 07:45 AM
