Nisei FMIC
Old Jul 26, 2005 | 06:06 PM
LordEvoIX's Avatar
Nisei FMIC
Anymore update on the Nisei FMIC? Seems to have gone all quiet after the initial buzz....real world reviews/dyno figures anyone?
Old Jul 26, 2005 | 06:12 PM
evo81's Avatar
Old Jul 26, 2005 | 06:23 PM
plokivos's Avatar
i've never heard the end of buschur and ams discussion on nisei and their test method, etc.
Buschur FMIC and AMS, can't go wrong with it, but I do like the nisei.
Old Jul 26, 2005 | 06:32 PM
nickracer9's Avatar
i have it and it's a great i/c. my intake temps dropped around 20 degrees. it was a noticeable gain. intake temps always match ambient temps, and as i boost the temps get cooler. thats my experience.
Old Jul 26, 2005 | 09:00 PM
Widebandphillip's Avatar
nisei gets my vote. Plus it looks awesome.
Old Jul 27, 2005 | 01:11 AM
LordEvoIX's Avatar
Originally Posted by evo81
That bad or are you another flame bait?
Old Jul 27, 2005 | 01:12 AM
LordEvoIX's Avatar
Yeah, I wonder why they never came out to defend their product. Seems to have gone all quiet recently.
Old Jul 27, 2005 | 01:13 AM
LordEvoIX's Avatar
Were you using the stock FMIC before the swap to Nisei? Just want to know the drop in temp was compared against which FMIC.
Old Jul 27, 2005 | 03:44 AM
Derek888's Avatar
I think David Buschur is right on the part where the Nisei fins are too dense which doesnt allow as much airflow to the radiator. I have showed a couple of friends and tuners and they all said the same thing about the airflow issue. Definately someone should test it against the other fmic's.
Old Jul 27, 2005 | 08:01 AM
evo81's Avatar
it's not that bad,but i remember a thread on some test that came back with real results,and not the ones that nisei said.br or ams fmic is better IMO.
Old Jul 27, 2005 | 08:10 AM
nickracer9's Avatar
as far as cooling goes my aem logs show the same engine temps before the i/c went in. i was comparing to stock intercooler. I also noticed my intake manifold and piping was barely warm as opposed to the stock i/c's hot to the touch. I believe most of the intercoolers out there are great, but the more surface area the greater the efficiency.
Old Jul 27, 2005 | 08:31 AM
LordEvoIX's Avatar
Your AEM logs showed engine temp via water or oil temp readings? If water temp reading, at what speed was the car travelling when the reading was taken? Just wanna make sure that the dense fins count isn't a big issue when the car is at speed. I'm thinking that even if there's a water temp raise of 5C to 10C, I can live with that If I'm not wrong, the extra power generated through the denser intake air should also generate more heat thus raising the water temp. It's all interconnected right?
We need more reviews from unbiased users...the vendors war is fudging the facts up badly
Old Jul 27, 2005 | 10:22 AM
nickracer9's Avatar
this was water temp at highway speeds and around town. there are no cooling issues. oh yeah, don't believe everything that a vendor says!
Old Jul 27, 2005 | 12:30 PM
Aby@MIL.SPEC's Avatar
The nisei fmic is a very tight fit & heavy.
Nice construction & a great warranty.
I needed to remove some material from the crash bar tabs that support the bumper skin, same thing on the bumper skin too.
undertray doesnt fit, unless to cut a lot off.
Old Jul 27, 2005 | 10:55 PM
Str8Ryda's Avatar
Well hate to break it to you but I don't think BR is right. If you did a little research you might find out that the BR FMIC is more dense than the Nisei.
BR has 18 fins per inch while the Nisei is 13.
This link is for anyone who's concerned about the radiator temps changing.
https://www.evolutionm.net/forums/sh...4&postcount=21
Cheers!
