Solid Lifters for the EVO
Old Sep 7, 2005 | 09:39 AM
evoviiiyou's Avatar
Interesting. Nice post.
Old Sep 7, 2005 | 09:45 AM
ASTROEVO's Avatar
Yo John.... thank you so much!!!!! muah !.... thanks.... ha ha.... Ive been looking for these!! woooohoooo..... gonna order.
Old Sep 7, 2005 | 09:55 AM
evoray's Avatar
would be a nice addition for companies that do head/port polishing build ups......nice!
Old Sep 7, 2005 | 10:09 AM
MalibuJack's Avatar
Very interesting.. I for one have run solid cams and solid roller cams for years on my older V8 cars.. But I got tired of adjusting valve lash..
If you have the patience for maintainance, there's quite a bit to be gained by having a solid valvetrain, but it does require maintainance (checking and adjusting lash at every tune-up) which is really no big deal for most of us. Not sure if the Evo setup would require checking and adjusting on a regular basis..
Old Sep 7, 2005 | 10:15 AM
ex-honda's Avatar
I ran solid lifters to on my old Chevelle also. Better response but more maintenance. It said that the "tic-tic-tic" noise were from the hydraulic lifters getting dirty which causes the noise, but they didn't take it step further and say that wear is also the causeof the noise which you will have after a while with solid lifters. On a stock head I see no really benefit but more maintenance but on a modified head, you will feel a big difference.
Old Sep 7, 2005 | 10:20 AM
Zeus's Avatar
It is a solid concept for the Evo... I'd like a set...
Old Sep 7, 2005 | 10:22 AM
marksae's Avatar
I believe CRCO tried to develop solid lifters for DSMs a few years back. I'm not sure what happened, but I heard they were unsuccessful.
Old Sep 7, 2005 | 10:33 AM
Ted B's Avatar
2V engines with large, heavy valves and big cams benefit greatly from solid lifters. The EVO engine may benefit from solid lifters, but I seriously doubt to the same degree.
The gentle ramps of HKS cams don't even necessitate stiffer valve springs, so I'd be doubtful that solid lifters are going to be of significant benefit. Additionally, EVOs with large turbos don't seem to lose power up top due to valve float, so is there really much to be gained?
If the engine had high lift cams with aggressive ramps, and was expected to turn 9000-10,000 rpm and make peak power in that range, I'd say it's a viable option. Otherwise, I'm doubtful that it's worthwhile for most street cars with smaller turbos and realistic 8k rpm limits, especially considering the expected increased maintenance.
I might also add that solid lifters tend to be noisier, and can create false positive signals from the knock sensor.
Old Sep 7, 2005 | 07:51 PM
timzcat's Avatar
There is a set on ebay from Norris Design.
Old Sep 7, 2005 | 08:36 PM
dryad001's Avatar
Call Buschur, when I was looking for lifters they had a set there.
Old Sep 7, 2005 | 09:09 PM
Zeus's Avatar
Very interesting... wonder if David has given them a try yet?
Biggiesacks
Dec 24, 2016 12:16 AM
MalibuJack
21
Jun 3, 2015 02:27 PM
JohnnyTSi
Northwest Region
Jul 22, 2010 11:54 AM
EvoJarHed
May 24, 2007 03:25 PM
John4321
25
Apr 26, 2005 06:17 PM
