Warning Hks Cam Gears
Old Sep 10, 2005 | 01:20 AM
Widebandphillip's Avatar
http://www.utahracing.com/Tech/hksgears/HTML/index.htm
There's a big thread on supraforums on how HKS will not replace these cam gears under warranty. Many other members have seen similar problems. I believe the problem is with both versions of the hks cam gears.
Old Sep 10, 2005 | 01:34 AM
btw the problem was that the timing belts were getting destroyed or wearing down prematurely.
Old Sep 10, 2005 | 02:12 AM
EvoBig16G's Avatar
Are these guys using aftermarket timing belts or stock timing belts?
Old Sep 10, 2005 | 02:18 AM
EvoBig16G's Avatar
HKS must have sold thousands of cam gears over many years. You would think there would be a lot more threads about defective HKS cam gears floating around the web. Is this a isolated case?
Old Sep 10, 2005 | 02:47 AM
i believe the cases were shown both with stock and aftermarket timing belts. Isolated case? I sure hope so. All hks cam gear users need to check their cam gear teeth to make sure. Destroyed a timing belt? This could be the cause.
Old Sep 10, 2005 | 03:22 AM
edwin's Avatar
that alrady happened in asia. hks parts for evo has been out many years. hks are not always good, could be bad!
Old Sep 12, 2005 | 12:53 PM
bump for good info.
Old Sep 12, 2005 | 01:34 PM
ArchangelGT's Avatar
I remember the problem being that people were not running their timing belt covers which let dirt and etc get into the grooves and overtime the belt would eat into the gear because of these particles.
A friend has this problem on AEM Cam Gears (I think it was AEM) also.
HKS Re-Designed their cam gear with nickle plated teeth. They still say to run the camgear cover for saftey.
http://www.hksusa.com/press/news_display.asp?id=2785
Old Sep 12, 2005 | 01:38 PM
i don't think that matters. Some of these guys ran their timing belt covers yet they still discovered that the cam gears were damaged.
Old Sep 12, 2005 | 01:51 PM
I just got off the phone with HKS b/c I was concerned about my own HKS Cam Gears (the new version). They had only like 3-5 problems with their old cam gears wearing out.
They haven't had any problems yet with the new nickle plated ones wearing.
Old Sep 12, 2005 | 01:59 PM
hksevo8's Avatar
please post a link to the supraforums post about this.
Old Sep 12, 2005 | 04:31 PM
http://www.supraforums.com/forum/sho...d.php?t=273431
stickied in the mkiv section. Registration is closed for now though.
Old Sep 12, 2005 | 05:44 PM
Gabriel J's Avatar
Well look at it this way...At least the adjustment bolts held tight
Migsubishi
Mar 27, 2016 07:22 AM
chamelieon
Mar 9, 2015 10:02 AM
redonion
Jan 15, 2012 08:11 PM
Force-Fed Performance
311
Jun 13, 2011 04:58 PM
djmikeymike
55
Mar 7, 2008 08:12 PM
