My TT numbers...why is the torque so low?
Old Sep 15, 2005 | 02:03 PM
  #121
03evo**'s Avatar
ur numbers wen u tuned my car were 298 torque 313awhp then dynno flashed i made 325 torque and 335awhp both at 21 psi but would have tuned higher but my plugs are bad so will be tuned at 23 psi making around 345 awhp n more torquen ill post the dyno sheet comparisons have a pass wit the tune the way it was then with the dyno amazing diff almsot 30 wheel and torque gain
Old Sep 15, 2005 | 02:04 PM
  #122
TurbotrixRacing's Avatar
Originally Posted by fsugatorbait
You cant compare readings on one dyno to the next, especially if its on a different day/location/time of year/etc...
Very true , but alot of people are doing it lately ...
Mark
Turbotrix
  #123
03evo**'s Avatar
yo bro i have the sheets to prove it we ran the car tuned by u then tuned by al ill put them up
Old Sep 15, 2005 | 02:06 PM
  #124
Your missing my point .. But thats ok..
Mark
Turbotrix
Old Sep 15, 2005 | 02:07 PM
  #125
fsugatorbait's Avatar
Mark
Turbotrix
True...however when you have car A with 264's tuned by Al, and car B with 272's tuned by TT and car A has a noticeable tq advantage via butt dyno on the street its going to make you think twice.
  #126
anjapower's Avatar
Not saying that. .. Just that @ 21 psi of boost you wont make 335 - 340 ft lbs of torque.
Every evo is diff .. bov ect.. a strong evo at 21 psi .. 310 , maybe 315 ft lbs. Keep in mind every pound you go up from 21 will increase your torque alot ..
These number are from our dyno .. Cant speak for anyone else..
Mark
Turbotrix
I know of an Evo with those mods that made 325wtq on your dyno, with the stock downpipe even...I'm sure there's more but that's the one that first comes to mind. What do you think is causing that besides the variation from car to car?
Also I have one more question...you tuned my car according to the boost guage. How can I make sure it is accurate? Should I worry that my dyno numbers might be off because of boost guage inaccuracy or should I be content that you would've picked up boost variation by knock activity while tuning?
Old Sep 15, 2005 | 02:08 PM
  #127
03evo**'s Avatar
welll i made the same exact numbers from wen i was tuned at turbo trix then wen we tested it to c wat it was making before al tuned it they were the same numbers on diff days a lil off liek 3 or 4 wheel n torque
Old Sep 15, 2005 | 02:09 PM
  #128
Someone recently tested their Defi boost gauge on a compressor w/its own pressure gauge and they mirrored eachother.
Old Sep 15, 2005 | 02:12 PM
  #129
03evo**'s Avatar
fs r u near milford or in milford alot
Old Sep 15, 2005 | 02:14 PM
  #130
bigjhoney's Avatar
Have you read the last 2 pages? No one is doughting you made more numbers, but you ever consider the fact that you will get a difference from 1 dyno to another. Only way to really check would involve going back to the original dyno. But with a custom flash from al I wouldnt be suprised if you made more numbers with the same boost.
Old Sep 15, 2005 | 02:15 PM
  #131
Are you talking about Gary? His car is a freak .. but his car isnt at 21psi .. of boost
Mark
Turbotrix
Old Sep 15, 2005 | 02:16 PM
  #132
03evo**'s Avatar
ok listen i know wat people r sayin wat im sayin is we ran the car wit the same tune on a diff dyno and it put down the same numbers as it did wen on the first dyno
  #133
anjapower's Avatar
Mark
Turbotrix
Lol...good guess. How is he running more boost on pump gas? Is it just not knock sensitive for some odd reason?
Old Sep 15, 2005 | 02:18 PM
  #134
bigjhoney's Avatar
LOL ok now i got you, should of said that before.
Old Sep 15, 2005 | 02:20 PM
  #135
Gary has one of those evos' ... We put his car spiking to 22-23 psi.. Tapering down. Without going too much into how i tune, you would see knock activity by about a 20whp loss , in the dyno graph. Almost like a giant step.. Gary's car always made good power and he's a great driver. His best with a slipping clutch was 12.4 .. Now with the new clutch and a new tune he's going back to the track
Mark
Turbotrix
