05 MR Boost Spike
Old Sep 29, 2005 | 07:30 AM
EMR8's Avatar
05 MR Boost Spike
I have an 05MR and In 6th gear at about 4K at WOT The mitsu Gauge spikes past 1.5 and pins its self there for a second before it tapers and the computer seems to regain control. The only mod i have is a AMS catless turbo back??? Should i be worried? On my STI I know that i had to port the wastegate because of the same problem once a turbo back was installed.Any one have similar issues?
Old Sep 30, 2005 | 08:03 AM
EMR8's Avatar
Bump!!!
Old Sep 30, 2005 | 08:06 AM
SR20DE-T's Avatar
I noticed this too with my 05 MR, but then I have a Dynoflash ecu, and TBE. Hmmm..
Kronik's Avatar
No, you should not worried. If you are running 93 octane or better you will be fine.
Old Sep 30, 2005 | 08:25 AM
Warrtalon's Avatar
It's natural to spike high in a higher gear at low rpm due to the amount of load. The downpipe reduces back pressure, which causes a higher-than-stock boost spike. You should be OK on pump gas, but it's probably causing the ECU to pull a ton of timing. I recommend not rolling into boost from low rpm in 6th gear...it's just not good for the car.
Old Oct 3, 2005 | 02:41 PM
EMR8's Avatar
I know why it happens but is there enough room for the injectors to compensate. Where is fuel cut on these cars???
EVOVIIImadrid
11
Oct 14, 2011 04:42 AM
SWOLN
Mar 31, 2008 03:09 PM
lijaci
Jul 31, 2007 06:20 PM
gixxer man
14
Mar 3, 2006 09:00 PM
TURBODAWG
Jun 24, 2005 10:04 AM
