What kind of gains With?
Old Sep 29, 2005 | 12:08 PM
EvoStvO's Avatar
Hey people I just bought my Tubed header & Ported turbo outlet my Light crank pully K&N Dropin filter and 3" Custom exhaust W/stock Silencer my 3" Down pipe will be here tomorrow....I Did a search and found to many different Numbers does anyone have an idea on what gains I will have on a 2005 Evo 8..Any help would be appreciated..Thanks.
Old Sep 29, 2005 | 12:24 PM
Compjoc's Avatar
I'd imagine maybe 15-25 hp. You'll need a tune to make good use of those parts. The light weight crank pulley isn't a good idea.
Smike's Avatar
First off - Is that with cat or without cat?
Secondly - get a flash. You will not notice much without that.
I would also go with the Walbro 255 fp.
See my sig. I have a similar setup minus the header, ported turbo, and pully. I made 320 whp and 305 wtq on a dynojet at about 68 degrees.
Old Sep 29, 2005 | 12:27 PM
Smike's Avatar
^^ Agreed the pully isnt on my list. Watch out with the header also, those can cook many parts near them, and they can adversely affect power. The stock manifold is actually decent.
Old Sep 29, 2005 | 01:29 PM
EvoStvO's Avatar
Right now it has the cat on it..but soon to be replaced with a Downpipe....I Read the crank pully is ok due to the balance shafts on the vehicle....What is a walbro 255?...Sorry not familar with some of there mods...I will do a search... Plus will i get a check eng lamp when i replace my downpipe?..Thanks again
Old Sep 29, 2005 | 01:30 PM
EvoStvO's Avatar
P.S putting the header on made a huge difference on the but dyno..I mean like Night and day.
Old Sep 29, 2005 | 01:33 PM
Smike's Avatar
A Walbro 255 is a fuel pump. Flows better than stock for when you need the gas. When you change to a high flow cat or without a cat - yes you will get the CEL light, but there are 2 fixes for that - mechnical in the how-to section and the chip verison that you have to wire in.
But again, a flash is what will bring the car to life.
Old Sep 29, 2005 | 01:41 PM
EvoStvO's Avatar
Perfect..Thanks again for all your help...I Used to have a Se-r SpecV and everytime i had a question i would get a smart *** comment back from TheVboard...So thanks for being cool all...
TxEvo8's Avatar
Get the MBC along with a flash.
kingRob757
Feb 27, 2016 01:57 PM
anthonyrb98
Nov 8, 2011 07:03 PM
2010 Rallihead
20
Jan 6, 2011 06:08 AM
heSOshAdy
ExtremeTurboSystems.com – WA
Jun 4, 2008 04:44 PM
skags
11
Aug 23, 2007 02:42 AM
