ACT clutch premature wear? help!
i have an act 2900 and she is toast, but i still drive the car.. slips in 5th gear on the freeway.. need to get a new clutch. Anyways, the act actually lasted a decent time for me so i cant complain and even though it is **** right now it still gets around
Originally Posted by vtsnake
you know i was just looking at those pics again and if you look at the pressure plate it doesn't look like it was applying pressure evenly. a third of it looks way f'd up. Dirk could the spring fingers apply pressure unevenly by chance? maybe some weak fingers in the bunch or maybe a warped pressure plate?
By the time you get that much heat into the parts, the metal moves around a lot. When the metal gets hot, it expands so the spots that are the hottest rise which makes them contact the disc more so they get more heat which makes them expand and rise, etc. When it cools the metal contracts. If you were to place a straight edge on the what looks like the hottest spots, they are actually lowest spots now. If you run it again, those same spots won't even touch and other spots will become the hot spots.
Graydon Richard
Lancer Engine Management / Tuning Forums
Aug 4, 2016 06:51 AM
20valves20lbs
10
Nov 12, 2015 09:44 AM
jasonsrt4
May 18, 2010 03:44 PM
05blue8
Aug 4, 2009 06:43 AM
