PO 300 code
Old Oct 13, 2005 | 03:49 AM
EvoulutionVIII's Avatar
PO 300 code
Ok so here is what happend drivin down the road on way home from work tonight i got some open road figure ill open the car up a bit Im running a stock turbo at 20 PSI so i get a over boost from the around 2500-3500 rpm range and my CEL comes on and IM like F&%k over boosted again so i bring the speed up slowly to get rpm up to 4000 then step on it and then the Motor gives a bit of a backfire i get out of the throttle and and look up there is a Police officer flashing me i pull over and he drives off (WOHA) so i drive the speed limit the rest of the way home i get the car in the garage and hook up my OBD II to the plug in and 4 codes come up the usual 2 when i over boost and a new one Iv never seen was a PO300 Muiltiple Cylinder Misfire Im like what is that from any help would be cool
here is mods
turbo XS Full exaust 3 "
Turbo XS down pipe
cat delete
perrin Short ram intake
perrin Boost tube
UTEC
Old Oct 13, 2005 | 04:11 AM
RogueSTi's Avatar
Wow, nobody has EVER gotten a 0300 code before...
Old Oct 13, 2005 | 04:50 AM
mump's Avatar
p0300 strikes again...
Old Oct 13, 2005 | 05:05 AM
navysevo's Avatar
i think you rerally need to get this car Tuned properly. i was having similar problems till al from dyno flash street tuned my car. everything went away and car is perfect.
Old Oct 13, 2005 | 08:13 AM
Soon2BEVO's Avatar
I have 27000 miles on my car. I was stock til 5000, then I did all the mods you can see in my sig... then at 22000 miles I got the P0300 code... why? Not sure. It comes and goes....
Old Oct 13, 2005 | 02:18 PM
Alias's Avatar
You need some punctuation marks in your paragraph. That was very difficult to read.
Old Oct 13, 2005 | 02:19 PM
vboy425's Avatar
don't worry about it, just egt bew spark plug it should it fix it, atleast that's what i did
Old Oct 13, 2005 | 02:20 PM
dan628's Avatar
with your mods you really don't need that intake, it may actually be hurting you.... put your stock air box back on and drive for a while and see how that feels and if you still get the same code....
Old Oct 13, 2005 | 03:00 PM
TylerO@WORKS's Avatar
If you have a '03 or '04 Evo, Mitsubishi offers a reflash for EVO's constantly getting this code.
The WORKS P2 flash is the only (as far as we know) flash on the market that incorporates the changes made by Mitsubishi with our own tuning.
If this is the first time you got the code and you think it was due to the tuning (or lack of tuning) then clear the code and check everything. Make sure your tune is dead on before flogging on the car, unless you like to blow motors.
Old Oct 14, 2005 | 04:45 PM
ok so its a on going problem i see i believe AL is comming to Seattle next month to worldoneperformance ill have them tune the car again then ill just baby it till then thanks guys
broddey
Feb 18, 2008 02:06 PM
Jedi_Gill
42
Oct 11, 2007 12:22 PM
nigletsyz
Mar 9, 2007 05:39 PM
Illrunya
Jan 23, 2004 09:06 PM
