Help! 5th gear grinding already
Old Oct 16, 2005 | 10:15 PM
  #31
Elitist Evo's Avatar
From: Where Ever the Smoke and Rubber takes me.......
Originally Posted by jmartinez1170
pm sent i dont even want to talk out here.
OHHHHHHHHHHHHHHHHHHHHHHHHHHHH PM ARGUEMENT TO ENSUE!!!! I want TIX
Old Oct 16, 2005 | 10:32 PM
  #32
chronohunter's Avatar
Originally Posted by ACTman
Transmissions don't fix themselves and syncros don't get misaligned, so my guess is that the clutch wasn't disengaging all the way. Check the fluid level in the clutch master cylinder. Does the clutch pedal feel any different? Did anyone happen to adjust the clutch? If so, that was it (common issue on the EVO). The only other thought was maybe difference in temperature. I have heard issues with different transmission oils causing sluggish shifting when cold. I am no expert on oil though. Whatever the case, I am glad it's now working for you.
I have 40k on my 03' and it has always had a 4th gear grind when shifting at the track (road racing). I figured I would just have to live it till I got a rebuild. I tried the SS line an removed the restrictor which made the shifting more positive but the grind remained. To make a long story short the last fluid change I put in BG syncroshift (1 not 2) and went to the track the other day and no grind(!) as a matter of fact I can make all the shifts quicker without the fear of grinding. I think I remember Jon at TRE saying he doesn't like the stuff but all I can say is it works
Old Oct 16, 2005 | 10:40 PM
  #33
EVIL_EVO_VIII's Avatar
Old Oct 16, 2005 | 10:45 PM
  #34
taenaive's Avatar
Originally Posted by EVIL_EVO_VIII
The grind has not come back at all, what rpms are you shifting at when you experience the grind? Are you shifting fast into 5th? I think John from TRE mentioned that shifting too fast will cause the grinding. I gave that a try and i have not grinded since then. Im gona remove the restrictor and adjust the clutch pedal also
It does grind when I shift fast. granny style shifting is okay for 5th. I can shift very fast 1~4 no grind. But 5th gives me the problem. I have never experienced this from any other cars. Mitsu tranny really suck. I will send my tranny to TRE someday.
Old Oct 16, 2005 | 11:14 PM
  #35
05evoGSR's Avatar
i have an 05 and get a crunch/pop sound when i shift into second and third and a 5th gear grind shifting hard and high rpms. The 5th gear grind only started at like 5k miles, but whatever, i dont slam it into fifth that often. When i do i could live with a lil grind, it still goes in fine.
Old Oct 17, 2005 | 07:57 AM
  #36
I spoke to Jon from TRE and he said the problems with grinding on 05 are fixed and this is what he told me.
If want the transmission to go from one gear to another the synchronizer will have to bring that gear up or down to speed with the rest of the transmission thus "synchronizing" the speeds so you don't get any gear crunch of the engagement teeth as the sleeve engages the gear...
Now if you are trying to rush a shift, the synchronizer will have to do it's job even faster and this can lead to either the synchronizer blocking the shift because speeds aren't synchronized or if you are ramming it into gear you can defeat the blocking teeth and it'll go into gear with a crunch and some damage to the blocking teeth on the synchronizer.
Now it's also possible, if you shift super fast, that you can get into gear minimal grind or crunch but you will eventually damage the engagement teeth on the gear and sleeve and this will eventually lead to a transmission that will grind. What has to happen in order for it to shift like this is an incredible approach speed of the sleeve, worn blocking teeth, and someone who will commit to ramming it into gear with all the force one can muster with no regard to the transmisson ever shifting the same again.
He also wrote this:
The problems have been fixed but there are several things that'll cause it to have problems such as:
Shifting too fast
Not letting off the gas while shifting
Improper use or clutch adjustment
Short throw shifters
Gear ratioon 5th gear
I havent grinded anymore since i stopped slaming it into 5th so i took Jon's advice on this. Hope this helps guys
Old Oct 17, 2005 | 08:41 AM
  #37
sleet's Avatar
The weather might be the cause of this, since it's started to get colder here i've started to grind 5th gear. We'll see tho..
Old Oct 17, 2005 | 09:07 AM
  #38
Same here, the other night was getting colder and thats when it grinded, but then again it was even colder last night and it did not grind, Im gona switch trans fluids to syncromesh, hopefully it will help
Old Oct 17, 2005 | 10:00 AM
  #39
GEARS's Avatar
Jebus on a stick, where in the world of evoM does it say that I don't like synchroshift? Is the signal to noise ratio really that bad?
For the record, "Jon at TRE has never posted or stated that he doesn't like BG Synchroshift in the transmission."
The paperwork that is included with every transmission that we build stated that I prefer a Synchromesh. At the very most I have stated that I prefer the synthetic version, BG2, for road race or wildly high power transmissions because it seems to cling to the gears better.
Jon@TRE
Old Oct 17, 2005 | 10:06 AM
  #40
GEARS's Avatar
He also wrote this:
Shifting too fast into 5th gear
Gear ratio on 5th gear being too wide
We also modify the engagement teeth so the transmission will take those fast shifts with less of a chance of grinding and increase the room for the synchro to wear before it touches down on the gear thus increasing the useful life of the synchro.
Old Oct 17, 2005 | 10:33 AM
  #41
ACTman's Avatar
Jon@TRE
I feel for you. And everyone using our clutches always get locked out of gear. The rumor mill is always alive and active on EVOM.
KillaYayo
Aug 31, 2016 07:31 PM
pb91
Jun 8, 2011 02:44 PM
Chompx88
Apr 10, 2008 09:23 AM
figuerda
20
Sep 28, 2005 07:33 PM
chase2000gt
Jun 21, 2005 12:05 PM
