309whp & 12sec timeslips for $400
This calculator is for whp:
http://www.dsm.org/tools/calchp.htm
Play with it. It has proven to be quite accurate in the past, especially the trap speed method.
The calculator gives you two numbers one based on ET (lots of variables) and one based on traps (much less variables). That's why it's a good tool. Ideally you want the two numbers to match, then you know you are taking advantage of your power with the other variables such as suspension, driving, traction etc.
Re: Re: 309whp & 12sec timeslips for $400
Originally posted by skibum
That's great but what numbers did the stock evolution put down on "your" dyno? In other words what is the gain??????
Thanx in advance.
Thanx in advance.
https://www.evolutionm.net/forums/sh...threadid=16200
309-258=51
Originally posted by zyounker
No, i am not a DSM guy. I traded in my WRX, and before that owned a 3rd gen RX-7..
Try researching what all the DSM people do to their cars. It is general knowledge and posted ALL over the internet..
I didn't post it in this thread because i would consider that rude. If they aren't willing to release the details then they probably wouldn't appreciate it if someone else did for them.
-Zach
-Zach
I've already done a lot of research, considering I don't own a 4G63 yet. I'll do even more before I even have an Evo, so I know what path I want to take. We weren't born with the knowledge so we do what we can to learn.
I stated that they might have added a MBC and a cheap cat-back. If you're talking about DSM-specific things, then maybe they removed the boost control solenoid restriction, or removed the BOV return tube, if the Evo is similar to the 2nd gen DSM. I don't know because I haven't seen an Evo in person. Maybe they removed an air box silencer or installed a low-restriction air cleaner. It would be nice if they told us.
Don't be afraid of being rude. This forum exists to help people. If you have ideas on how to make power on the 4G63, feel free to share them.
Well, unfortunatly until i do it myself i would not feal comfortable posting it here as if i had done it..
Next week, i will be doing a "Test pipe" to remove the cat. I will modify the wbo2 sensor so i don't get a check engine light from removing the cat..
Use an MBC to hold 19PSI till readline and use an S-AFC to tune it.
That should do an easy 300WHP. and low 12s 1/4..
The above should cost ~$400
-Zach
-Zach
Originally posted by ru4real
My guess is a MBC and cat-back exhaust, maybe a testpipe. I'd like to see the dyno charts also.
Either way, I'm curious to learn what AMS did to their Evo...
Originally posted by BatmanGSX
Also, AMS has put a few cars into the 10s. Has Shiv ever even come close to making that kind of power?
AMS doesn't charge $1000 for tooning session that gets you 5whp either. Who you gonna trust?
If you want to attack us for some reason, please do so with a slight regard for the facts. Anything less is disingenous and just draws light to your actual motives which are questionable, to say the least. Sorry for butting into this thread. Let's at least try to play nice.
Best Regards,
Shiv
Originally posted by AMS
For example tonight we put down 604whp on a '91 Eagle Talon street car and I know this car will go 10.4's at 137mph. This same car put down 515whp a few months ago and went 11.0 at 129.8mph (hitting stock rev-limiter).
-Martin
-Martin
Originally posted by shiv@vishnu
All of them in the 11 and 10s. Whoop-de-do. It's not hard considering the octane levels and 10-11 second load durations I tune for. I rarely pat myself on the back when one of the cars I tune runs quick.
Best Regards,
Shiv
Best Regards,
Shiv
Originally posted by 122andy
Dont forget to mention what Adams Galant dynoed vs its ETs. Isnt it the quickest/fastest GVR4 in the world?
Damn you're hot on our tail with your GVR4. Cant' wait to see it at the Shootout this year. The Galant is getting some new things done to it and it should be done shortly.
Martin
We're using our dynojet dyno and we put down 258whp on a stock evo with absolutely on mods or tweaking.
Martin
Martin
Keep these numbers handy when you guys want to compair AWD dynos. Driveline loss for a dyno dynamics is 1.4, dynapack is 1.3, mustang is 1.26 and dynojet is 1.19 (these are for a WRX but according to the few evo8 dyno scans ive seen, they hold true for the evo!).
So if your car put down 250whp on an AWD dynojet:
250 x 1.19 = 299hp at the flywheel
the same car would put down 214whp on a Dyno Dynamics (at the same temperature, elevation, gas, moon phase, ect):
214 x 1.4 = 299hp at the flywheel
These numbers are not absolute but they give you a damn good rough guess. Just saying "You guys should ignore X dyno" because you DONT LIKE THE NUMBERS is petty and uninformed. If you still dont get it and just want to stroke your ego, convert your car to 2wd, run it on a dynojet and show your friends.
Thanx in advance.
Thanx in advance.
It had that info in it.
I dont understand why everyone is all of sudden getting all worked up over some dyno runs and tuning shop practices. If this normaly well informed online community that I have been a part of for so long continues bashing the vendors and tuners that are only providing you with free information then fewer and fewer vendors will be posting there results here at all. I always said that any info is better then no info. Lets try and lay off a little guys.
My 2 cents
My 2 cents
David Buschur
119
Apr 4, 2008 11:27 AM
David Buschur
Aug 26, 2005 08:24 AM
David Buschur
56
Aug 24, 2005 09:57 AM
nextgenerationx
Lancer Aftermarket Forced Induction Tech
83
Feb 11, 2005 04:40 PM
