Help!!!! Clutch Pedal Stuck!!
Old Oct 23, 2005 | 05:07 PM
MuslimEvoFreak's Avatar
Unhappy Help!!!! Clutch Pedal Stuck!!
Ok, heres the thing......About 15 min ago at 6:50 pm, I was on my way home from work (Taco Bell) and I noticed that my shifting became rough. Well my clutch pedal felt too short and weird. So I stopped on the side of the road and look at my clutch pedal. What I found out was weird, my clutch pedal was stuck in the middle. Like my accelerator and brake pedals were higher up than my clutch pedal. What I ended up doing was I lifted my clutch pedal up with my hand and it popped up. I started driving once again and shifting went back to smooth. So technically, what I am trying to ask is what could be wrong and has anyone experienced this. BTW, this is an 05 EB evo with 6,500 miles.
Old Oct 23, 2005 | 05:27 PM
blink2824's Avatar
it could be the slave cylinder ...faulty part...thats what happened to my 2003 bby evo at around the same mileage. The clutch pedal just became worse and worse and stuck farther and farther toward the floor, as I had to pull t back p with my foot. Mitsu should replace it...take her in! That what I think it is anyhow ...good luck
Old Oct 23, 2005 | 05:33 PM
smokedmustang's Avatar
Or you could have air in the system, the clutch going by by, alot of other things, check your brake fluid level. I believe the clutch uses the same level/fluid. good luck, and keep us posted!
Old Oct 23, 2005 | 05:34 PM
THANX A LOT MAN!!! I was thinking of taking her in tomorrow for this reason and for another reason.
Old Oct 23, 2005 | 05:37 PM
I don't think it could be my clutch SmokedMustang because I just got it replaced 2 months ago. Atleast I hope not its my clutch!!!!!!!!
Old Oct 23, 2005 | 05:39 PM
I have been thru 2 clutches in a short period of time. If it is a twin plate, could have warped a plate, causing this problem. hope it is not, could just be air in the system!
Old Oct 24, 2005 | 09:45 AM
ACTman's Avatar
It could also be that the release bearing detached and by lifting the pedal it allowed it to snap in place again and it went back to normal.
Old Oct 24, 2005 | 12:23 PM
Ok guys, good news...The dealership is ordering the slave cylinder for my car and it is free because of warranty!!! Thanx for everyones help.
silentkiller
Jan 19, 2013 01:14 AM
kalib
Jan 17, 2011 06:52 PM
whiptheevo8
Jun 20, 2009 09:17 PM
03redtype-s
10
Sep 17, 2008 10:13 AM
Bar
15
Jul 21, 2008 08:42 PM
