The not-so-offical EVO 9 ECU tuning thread
Originally Posted by masschaoz
hmmm.. ur located in asia.. me too! sg?? i wld think the effect would be as good if the ecu is reflashed in the states and then plug back onto the asia climate.. wld be good if shiv cld pay us a visit n tune our cars!
yes! SG it is. did the blown turbos give it all away? :P how's your car holding up? in any case, i'm still eagerly awaiting shiv's reply to see how feasible tuning/flashing ecus from abroad. and how long it'll take.
i've seen your other packages on your website shiv. i'm assuming that pricing for the 9's arent out yet?
thanks in advance...
Originally Posted by Vishnu_Evo8
oh btw i got a chance to ride in the IX with the flash, and my god... its disgusting. Its as smooth as ruchmate's 05 e55 amg.
Originally Posted by streetturbo
Don't understand what is bad about that. Any other impressions with the ix? Does it pull comfortably to high speeds?
Wow, 270whp, again proves my point that the IXs are really strong. I believe (stock) lower powered ones will dyno at 05 VIII levels, while (stock) average IXs will make more power, and (stock) higher powered IXs will dyno a lot higher than VIIIs.
Originally Posted by fire-ballz
shiv,
so the main idea of this 9+ page post is that the new EVO 9 comes out of the factory underated at 286 hp. the true hp readings for the EVO 9 should be ~320-340. am i correct?
-shiv
well im really impressed, makes me want to get the evo9 earlier. i'm new to this site and most likely a newb. ^_^ when i get it imma have to break it in, then i can flash it right? if so, imma have to do it with VISHNU! well nice to meet yall
Shiv, if you get the time while you are in your dyno program. Will you post on the same sheet a dyno of a average VIII that was stock on your dyno along with the Ix you have dynoed and also the Ix cam run that was zeroed out.
I would like to see on another chart a tuned IX vs a tuned VIII.
Bump for seeing the IX tuned to 93.
Thanks for posting those 2 sheets.
Originally Posted by Doogie Howser
Any update on how the IX did tuned with a vishnu turbo-back exhaust?
The exhaust will just require simple remapping over what we currently have. The key is to get a solid foundation first with the stock car.shiv
