The not-so-offical EVO 9 ECU tuning thread
Old Nov 28, 2005 | 08:08 PM
  #286
EVIL_EVO_VIII's Avatar
Originally Posted by Noize
More than that! That car is kicking the crap out of mine with next to no mods, and I have a ton.
Do you have an 05 or an 03-04?
Old Nov 28, 2005 | 09:44 PM
  #287
Noize's Avatar
EvoM Administrator
03, but it doesn't matter. I have a TME, IC, 93 octane, test pipe, cam gears, and cams in addition to what that car has and still don't have that kinda torque.. Even if you have an 05, they're all getting destroyed by that reflash+exhaust Mivec car in this thread.
Old Nov 28, 2005 | 09:54 PM
  #288
Have Nick tune your car then, that might chance
Old Nov 29, 2005 | 06:33 AM
  #289
Noize's Avatar
EvoM Administrator
It won't. I'm sure Nick is great, but VIIIs don't make the power IXs will with light bolt ons.
Old Nov 29, 2005 | 07:13 AM
  #290
res04's Avatar
Im thinking the IX turbo will be a great stealth mod for many a VIII owner.
Old Nov 29, 2005 | 07:25 AM
  #291
NoTec's Avatar
I'm thinkin I want a IX in my driveway quite soon!!
Old Nov 29, 2005 | 07:33 AM
  #292
wtz's Avatar
wtz
Is the IX cat the same as the VIII, or could it be freer flowing?
Old Nov 29, 2005 | 07:57 AM
  #293
Ben - EcuTeK's Avatar
Congratulation on your work Shiv !
I'm amase at the Trq curve you could get out of this motor on such mods.
I also received an e-mail from EcuTeK Japan about cams for the EVO9, Jun is doing some development work and they should come out by the spring.
They also said that EVO8 exhaust cams gave some very good results on the EVO9.
Old Nov 29, 2005 | 08:02 AM
  #294
res04's Avatar
Not sure, it is different cosmetically in that the o2 sensor is attached to it vs. after the cat on the VIII however.
Old Nov 29, 2005 | 11:15 AM
  #295
Luffy's Avatar
My new IX MR will be here tomorrow! Now I'm know who I want to tune it!
Old Nov 29, 2005 | 11:33 AM
  #296
Terry S's Avatar
Now that the car is finished... Final Tally?
Terry S
Old Nov 29, 2005 | 06:37 PM
  #297
SmokinJoe's Avatar
Off-topic, but..
That's incorrect - the 02 is attached to the pipe after the cat on the IX. The cat is exactly the same.
The exhaust is nearly the same as the VIII (Bends, mounting points, etc) Some downpipes will have to be clearanced slightly to make room for the larger center diff. Also the turbo elbow has a larger exit whereas some donuts wont fit over the flange.
Old Nov 29, 2005 | 07:11 PM
  #298
shiv@vishnu's Avatar
Terry S
On 91oct, it comfortably made anywhere from 290-295whp. On 93oct, it made 305-310whp. I have some more IX to tune during the next 2 week introdructory special so I'm eager to see how much tweaking is necessary to adapt the map to different cars.
Cheers,
Shiv
Old Nov 29, 2005 | 08:00 PM
  #299
res04's Avatar
Originally Posted by SmokinJoe
Off-topic, but..
I have an IX MR sitting in my garage that I installed a Greddy Ti cat back on it and had to plug the O2 housing built into the cat back because the IX no longer uses that location.
And to quote Buschur:
The
> exhaust fits BUT there are two slight modifications that have to be done
> to
> the car itself. They are quite simple but the new EVO9 has two new parts
> the old cars did not. No way around making a 3" exhaust fit without doing
> these mods to the car. The car has a new small heat shield around the
> carrier bearing right behind the cat. This has to be removed. The car
> also
> has the 02 sensor right in the cat now, so there is a bracket the bolts to
> the catback flange that will not work with 3" diameter tubing
Old Nov 29, 2005 | 08:14 PM
  #300
res04's Avatar
Do a search for exhaust + IX + cat and you will find tons of references to the o2 in the converter for IX change.
