Engine Blew!!
Old Nov 24, 2005 | 11:42 AM
  #31
bpclements's Avatar
Originally Posted by SaabTuner
I'm not sure I'd say that's an injector problem. I think it might have been a cooling issue either with the coolant or the oil-squirters for the pistons. #3 is showing obvious signs of overheating.
I would check the oil-squirters for those two pistons.
That's a very good point. I didn't think of the oil squiters causing the problem on number 3.
It's all good though. I'll be getting a fully built long block from Mark at TurboTrix!!!!
Old Nov 24, 2005 | 12:46 PM
  #32
SaabTuner's Avatar
Awesome.
You're probably right about the injector being the problem for cyllinder 2. But, if the injectors check out ok, it's still possible that a clogged oil-squirter caused some problems there. A hot piston tends to detonate more, which in turn makes the piston hotter still, which makes it detonate more still etc etc etc.
Probably still the injector though.
Old Nov 24, 2005 | 12:51 PM
  #33
bpclements's Avatar
Thanks for all the tips. I'm sure I'll find out what the cause was.
Old Nov 24, 2005 | 03:08 PM
  #34
sethrichmond's Avatar
dude
take a serious look at the buschur stoker. i am reving to 8500 and there are a few taking it to 9000.
i put down 500whp at 25psi on a mustang dyno
that engine is sic
at least call them
Old Nov 24, 2005 | 03:30 PM
  #35
bpclements's Avatar
Originally Posted by sethrichmond
dude
that engine is sic
at least call them
I don't know Buschur like I know Mark. That is one of the reasons why I like going to Turbotrix for tuning and now for my engine build. No doubt the kit looks good. It's just not what I want.
Thanks
Old Nov 24, 2005 | 04:01 PM
  #36
FLAEVO's Avatar
What fuel pump were you running.
Old Nov 24, 2005 | 08:32 PM
  #37
bpclements's Avatar
Walbro 255LPH.
Old Nov 25, 2005 | 08:50 AM
  #38
MrSpeedDemon's Avatar
Damn, ouch.......best of luck w/ the new one
Old Nov 25, 2005 | 09:37 PM
  #39
BoostedEvo21's Avatar
Yeah Barry, Sorry to hear about the motor. Just to think last weekend were all out driving around, and now....well you get the picture. I am glad you are going through Mark and paul at TT. After meeting them the other weekend I would trust them completely. If there is anything I can do to help let me know!!!!
Old Nov 25, 2005 | 10:28 PM
  #40
w_tomas's Avatar
I can't wait to see the tt longblock Barry. One positive thing that has come out of this is that your car will be a lot stronger than it was. You know if you need anything I got your back man.
Old Nov 25, 2005 | 10:29 PM
  #41
bacalhau16's Avatar
Turbotrix is definitly good people and all i have is a flash from them, but just from the conversations i had with mike and mark i know that i will continue to go with them for service.
definitly curious as to why the motor blew. 56k is a little high i guess, but not enough for that to happen. did u perhaps just get a bad tank of gas, go somewhere different maybe. this always worries me when i fill up!
Old Nov 26, 2005 | 11:32 AM
  #42
bpclements's Avatar
I should have some answers once I get the injectors looked at.
Old Nov 26, 2005 | 12:35 PM
  #43
bacalhau16's Avatar
u sound pretty positive that it is the injectors. did u know if the duty cycle was too high for them, or something like that?
Old Nov 26, 2005 | 12:49 PM
  #44
Smogrunner's Avatar
Very unlikely it was the injectors. I made 372whp 357tq and ran 11s in the 1/4 on the stock injectors and they never maxed out or failed.
Old Nov 26, 2005 | 12:55 PM
  #45
w_tomas's Avatar
Highly unlikely - yes, doesn't mean it can't be the culprit. Barry is sending the injectors out to rule out the possibility of them being it. I see your point, but they are two seperate cars.
