PLEASE look inside!! Motor problem that i cant figure out
Old Dec 3, 2005 | 03:41 PM
dsmythe2's Avatar
Do you have a CEL showing? Can you pull the code if it does? PO355 is the crank position code if timing is the issue.....
Old Dec 3, 2005 | 03:59 PM
platinumspecv's Avatar
smartest thing to do is to check to see if ur motor is okay first. Checck for the worst first
Old Dec 3, 2005 | 05:28 PM
wprettyboy's Avatar
well it looks like its my head, took the cam gear cover off and the cams are not turning!!!! the belt is worn on the crank side cause topend was not turning. pulled the plugs and tried to turn the cams, they would not move at all!!! so anybody know what could have happened???
Old Dec 3, 2005 | 05:40 PM
WHTEVO's Avatar
Originally Posted by Ultimate CC
Go check your engine fuse and replace that, then go under the car and electrical tape the 02 sensor where you grounded it out, then take a mallet and bang the area around it so that way it doesn't rub. Problem solved. Now you can sleep tonite haha.
he said his engine turns, just not freely. if the engine fuse was blown the car wouldn't do anything, it wouldn't even try and crank.
Old Dec 3, 2005 | 05:42 PM
drillteamleader's Avatar
you have bent valves probably.
WHTEVO's Avatar
almost sounds like your engine seized up on you. have you checked your oil? you can't turn it at all by hand? good luck.
Old Dec 3, 2005 | 05:49 PM
evolved4g63's Avatar
As of right now its not sounding so good for you. If it doesnt turn over , espescially with the plugs removed something is where its not supposed to be. You didnt hear anything the last time out with the car? If the Tbelt is worn, prolly cause its easier to tear up rubber than metal. Not sure what you want to do at this time. Is the car still under warranty? Or you can start ripping the manis off the head and see whats going on. How long has the crank pulley been on for?
Old Dec 3, 2005 | 05:50 PM
elhalisf's Avatar
spin it the other way. a valve might have broken and stopped the engine from moving.
Old Dec 3, 2005 | 05:58 PM
wprettyboy's Avatar
the oil level is fine. i'm going to pull the head tomorrow to see whats up. thanks for all the ideas. i will report back on what i see inside!!!
Old Dec 4, 2005 | 01:27 PM
wprettyboy's Avatar
pulled the valve cover today, cams look fine and the valves look ok to the naked eye. still cant turn the cams. only thing i can think happened was maybe the timing belt tensioner broke and its holding the belt. Has this ever happened to anyone!! or is this possible whats wrong???
Old Dec 4, 2005 | 01:51 PM
well if tensionor would fail - ur timing would be all off (you would noticce it). Big loss of compressoin. Get the compression test done asap man. Check if ur motor is okay then go and figure out what the problem is after the main diagnostic is done
Old Dec 4, 2005 | 02:10 PM
wprettyboy's Avatar
how can i do a compression test when the top end isnt turning?
Old Dec 4, 2005 | 02:16 PM
Greg K's Avatar
you need to pull the head, then the cams and see what's bound up. There is a mechanical bind of some sort if you cant physically turn the cams with a ratchet. Also your valves will be bent, because if you cranked the bottom end without the cams turing 50% of the valves are done.
Old Dec 4, 2005 | 02:22 PM
wprettyboy's Avatar
if the timing belt tensioner broke, would that be under warranty? modding the car should not have an effect on that. If that is the case they should fix the belt and the valves. is there anyway possible the valves are fine
Edit-- Could the crank pulley that i put on have anything to do with this? its just weird that one week to the day that i installed it this happens!!!!
Old Dec 5, 2005 | 07:37 AM
wprettyboy's Avatar
one of my friends is bringing his bore scop over tonight, should be able to see something with that!!! I will update after that
