Again!!!
Old Dec 26, 2005 | 07:12 PM
  #31
silverofs's Avatar
Originally Posted by EVIL_EVO_VIII
WHen your blew, was the coolant coming out from the passenger side of the car? Side of the motor?
it's sounds like you have a leak from either the waterpump or the freeze plug.... is it coming from the timing case???
Old Dec 26, 2005 | 07:40 PM
  #32
EVIL_EVO_VIII's Avatar
Not sure. I also think it has to do with the freeze plug. Ill find out tomorow for sure. They started working on it today and ill have an answer tomorrow
Old Dec 27, 2005 | 08:20 AM
  #33
Just called the dealer and just as i thought, it was the wp/freeze plug again!!!!!!! So they ordered a new one and a new timing case cover that was damaged in the process. Will have the car back tomorrow or thursday the lastest, YAY!!!!!!!!!!!
Old Dec 27, 2005 | 04:47 PM
  #34
GEARS's Avatar
https://www.evolutionm.net/forums/sh...ht=freeze+plug
Old Dec 27, 2005 | 05:38 PM
  #35
Thanks!
Old Dec 28, 2005 | 06:03 PM
  #36
Should have my car back, up and running tomorrow
Old Dec 28, 2005 | 06:07 PM
  #37
gunnerman's Avatar
that sucks..i had a coolant leak problem with my '03. althought i don't hvae to fix it anymore...i totalled my evo on christmas night...does anyone need oil cooler send or return hoses?...i got them for 30% from south coast mitsu..can't return them since they're special order.
Old Jan 3, 2006 | 08:43 PM
  #38
BURNALL_4's Avatar
sry i didn't get back to you sooner, no it was in the driver side but more in front
Old Jan 4, 2006 | 10:27 AM
  #39
UPDATE:
Spoke to the service manager and they inspected the motor. Pistons, valves and everythig looks good which is good news. The head gasket looked discolored bc of the heat and gases. The head looked good also but they sent it to the machine shop and have it inspected just to make sure its still good. I am getting everything under warranty, no questions asked!! I will find out tomorrow about the head results. So far so good! Ill update this tomorrow
Old Jan 6, 2006 | 01:13 PM
  #40
UPDATE:
Went to the dealer today and the car is still apart. I got to inspect the motor. The pistons seemed to look good and everything else looked the same from what i coulde see. However,the head gasket looked dark and discolored. The dealer is still waiting to hear back from the machine shop that it was sent to, to have it inspected and cleaned. I should get the car back hopefully sometime next week. As much as im hating my car right now, i miss it
Old Jan 6, 2006 | 01:29 PM
  #41
4cdndctn's Avatar
If you can pay extra for them use the stronger head studs (ARP), do it.
Old Jan 7, 2006 | 10:20 AM
  #42
Thats exaclty what i have in mind! Im going to ask them on monday and if they say yes, ill take them the head studs. Good idea to do since the head is out
ImJoey
Oct 7, 2008 02:23 AM
jab_phoenix
Oct 25, 2007 06:11 PM
bruce988jl
Jun 28, 2007 06:33 PM
Turtal
Apr 14, 2006 10:42 PM
vegasboy301
22
Apr 4, 2004 10:56 PM
