Evo Engine Management / Tuning Help!
Happy New Year to all.
Please dont tell me to use the search button because, I did for the last few days and nights.
I dont have a clue which way to go with the engine management/ tunning...
This vehicle is a daily driver, not a drag racer, being built to show, a few HPDEs and Time Attacks....
Down below are mods completed and future mods
My vehicle is registered in New York...so from what Ive been reading...
AEM/EMS is scratched off the list, because of New Yorks inspection tests.
TURBO XS UTEC I'm not sure... it sounds like exactly what i need, but from reading the forums 75% of its users are getting rid of it since there has been no upgrades for more than a year.
I see there's other options like: (which I'm still reading up on)
ECU+
AL'S FLASH TUNE
HKS FCON
MAFT PRO
WORKS BRAIN FLASH
What do you reccomend and WHY?
thanks
BASIC MODS
COMPLETED
2.3 Stroker
- w/ B J&E Pistons 9.0:1 (ceramic coated)
- NITRIDED crank
WORKS Exhale Downpipe
WORKS Exhale High Flow Cat
WORKS TKS Clutch Line
GREDDY TI Racing Muffler
GREDDY TIMING BELT
GREDDY STY Grounding Kit
AUTOMETER CF Oil Pressure Gauge
AUTOMETER CF Oil Temp Gauge
AUTOMETER CF Water Temp Gauge
AUTOMETER CF Boost Gauge
AUTOMETER CF EGT Gauge
AUTOMETER CF Fuel/Air Ratio Gauge
WALBRO 255 Fuel Pump
ARP HEADSTUDS
TURBOSMART EVO Specific BOV
K&N Filter
SAMCO Hoses
GRAM LIGHTS 57S (8.5 x 17)
TOYO RA-1 (255/40/17)
WHATS NEXT
HKS Cams 272 Intake 264 Exhaust
WORKS TKS Brake Lines OR ENDLESS Brake Lines
WORKS Rotors OR ENDLESS Rotors
WORKS Exhale O2
WORKS WRP Camber Plates
WORKS WRP Rear Pillow Ball Mounts
??? Intercooler
AEM Adjustable Cam Gears
CUSCO Sway bars
CUSCO Type 1
CUSCO Type 2
OHLINS Coil overs
??? Boost controller
Tune
ECU+
AL'S FLASH TUNE
HKS FCON
MAFT PRO
WORKS BRAIN FLASH
thanks
BASIC MODS
COMPLETED
2.3 Stroker
- NITRIDED crank
GREDDY TIMING BELT
ARP HEADSTUDS
K&N Filter
SAMCO Hoses
WHATS NEXT
WORKS Exhale O2
??? Intercooler
CUSCO Sway bars
CUSCO Type 1
CUSCO Type 2
OHLINS Coil overs
Tune
I run the ECU+ unit it is a very user friendly tuning tool. It does everything you need it to do and more. It has a built in GM-MAF Translator, and it also has nice features like an idle and decel stabalizer. You can read about the full fetaures of this unit at www.ECUplus.com If you need any more help feel free to PM me.
maft pro is like the new cool thing, they're picking up lots of features but maybe in its current form it's not as complete as say ecu+, however it will be. so it depends on when you wanna slap all this together.
ECU+ is also constantly adding features as well. And there are plenty that are going to be added in the near future as well. A few things that were recently introduced for the ECU+ are EGT logging and full OBDII integration as well as. This is an exciting product that will continue to grow and make it the most advanced "piggyback" controller on the market.
Have you looked at the Map ecu? My friend is putting the systyem on his car this week. they used it on a 350z that twin turbo, sc430 thats twin turbo, and a bunch of supras. all putting out bg numbers.
heres the link www.mapecu.com you can pm me as ill be putting it on this weekened and ill let you know how things work out.
well we used it on plenty of others cars like my friend above has metioned. i jus want to see what it can for the evo since i think ill be one of the first to play with it on my car. i jus like going with somethjing of this nature map ecu, maft pro, etc instead of full out standalones. i like driving my car everyday and its not a full race car which is what standalones are really made for. well see how things go. i might just get the maft pro and put them against each other and see what the out comes are. jus for thepurpose to see what both can do for our community.
I hug my ECU Plus nightly.
It's constantly being updated. It has GREAT logging features, a great interface for logging, etc. A street dyno function which is very accurate if you use it right, plus many many other things.
The ability to mess with adding or subtracting timing was a godsend for me to get a knock free tune on 91 octane cali **** gas.
You can also use a laptop or a palm pilot for tuning and logging. Tom just recently made map switching via the palm pilot as well. (it's been there for the laptop)
truthfully it usealy best to leave timing where it is. Is messing with timing and get a few hp more worth your block popping. not to me. like i said map ecu is for people that want there car as a daily driver not a race car. i mean weve built countless amount of car making over 600 whp just using map ecu. but each to his own.
