View Poll Results: Which exhaust sound do you like the best?
Buschur Racing race muffler.
44
15.49%
Buschur Racing new designed muffler
240
84.51%
Voters: 284. You may not vote on this poll
Sound clips for BR exhausts....poll attached.
WHAT??? Damn I hate you IX *****es!! LOL Nice numbers on minimal stinkin mods.
I'm just jealous, is all. Well Jeff, if we go down to Portland together I guess we'll really see you put my '05 to shame....but I still want to see it....hehehehe
Here's a video of my car on Pruven's dyno last night with the Bullet muffler w/test pipe. It's cruising around 3000rpm for a while, then a WOT pull:
http://media.putfile.com/Evo-IX-Dyno-March-06 (give it 1-2 minutes, it loads slowly)
Dave, can you make it that this new bullet muffler would fit your old Buschur TBE. We all would like to have this muffler piece too but I'm not going to get rid of my old TBE to buy your new one so I can have just the muffler difference.
Originally Posted by SPANKED
Impressive, not too loud either especially with a test pipe...what you lowered on Bernardo?
I cannot get the new mufflers out there to owners of the older system simply because I cannot gaurantee the fitment. What I can do is sell the muffler, bend, tip and hanger as a "kit" and you can weld it together on the car so it fits just the way you like it. If you want to do this then yes, I can sell it, $225.
David Buschur
www.buschurracing.com
David Buschur
Just installed this exhaust on my car with the test pipe. All i have to say is awesome, sounds great and a good power increase considering the only other thing i have is a K&N drop in filter. The only thing i don't like are the band clamps for the slip fit parts of the exhaust. The one after the test pipe was leaking a little bit so i moved it around and retightened it. I can't feel or here any exhaust gases coming out now just a little condensation came out when i first started the car after it was sitting for a while. The back band clamp connecting the muffler and cat back pipe is leaking a little bit too. I'll try to move it around a little and retighten it tomorrow to see if i can stop the leak. I may end up just going to a local shop and have them put some flanges on the exhaust if i can't fix the leaks. There is no gasket sent with the kit for between the downpipe and test pipe/HFC and Buschur says you don't need one but i'm going to end up putting one in there anyway. I don't think i've ever installed a flanged exhaust without gaskets. I would also get some gaskets for between the test pipe/HFC and cat back pipe and the muffler and cat back pipe if/when i decide to put flanges on. Other then the little leaks at the band clamp spots the exhaust is awesome. Like i said before looks awesome, sounds real good and a good power increase. I really like how it almost looks stock besides sticking out the bumper a little bit, which is better anyway so it doesn't melt the bumper. Can't wait to get my MBC on tomorrow then have Al tune me on Sunday, hopefully put down close to the same power as bernardo did...
That's the only thing holding me back from this exhaust...seems like a headache making sure nothing is leaking with the slip fit design...I'll take the weight hit just give me flanges on all ends.
If the band clamps are leaking, you just need to tighten them more. I had the same issue of not torquing them down properly. Use a large breaker bar or torque wrench to tighten them fully, and the leaks will stop.
Guest
Posts: n/a
I like the way the new one looks and if the br racing didn't exist, that would be my pick, but you can't top the old one. There's nothing that sounds better. I don't have to worry about the police one mine since I'm in the military and the car's registered in a different state, so I definitely have to go with the louder, more aggressive one. I hope they keep all of their different exhausts. Buschur's the best.
Hey did you guys see that Buschur now offers this turboback kit with v-band clamps...
Check it out...http://buschurforums.com/forum/showt...3703#post63703
FWIW, I have the new Buschur 3" exhaust with HF Cat and new Bullet muffler.
I tested it with my spl meter and although I'm not an expert by any means, here's what I got:
showing about 90 decibils at the rear of the car at idle about 2 foot behind the tip. This was in my garage, so there might be some echo'ing or something.
showing about 75 inside the cabin under the same conditions.
I just ordered my Bullet TBE with vclamps and a SPECIAL cat...angle cut non rolled tip.
with a bunch of other goodies , battery kit,upper pipe no bov and maf pipe with filter...HorsePower Freaks Lower Piping
Cant wait to install everything then get it flashed...2 weeks wait will be worth it but still hard...
