EVO IX Dyno Thread
Here's an attempt to bring this thread back on topic
STOCK Evo IX, 1066 miles
DynoJet @ Mach V (01/07/06)
Peak HP: 251@6500
Peak ft-lb Torque: 247@3750
As for the disappearance of the graph between 4000 and 5400 RPM, well nobody quite figured that one out. But earlier that day another IX was put on the dyno and the same thing occured. Has anybody else had this sort of thing occur on the IX?
Peak HP: 251@6500
No, we don't do external wastegates on the stock turbo on the VIIIs. It's certainly too early to be worrying about it on the IX turbo, and it probably won't be something you ever worry about. That's something you do way down the line when you're overruning the internal wastegate.
But you will get some nice gains with a EWG even on the stock turbo.
My buddy, who has a sti, put a 38mm EWG on the small stock vf-39 and gained a good 20whp over the IWG. I plan on going EWG when I start modding.
Also evom.net member Wilson1, broke the stock EVO record at Gruppe S (Mustang Dyno) when his IX dynoed at 236.9WHP/243.1WTQ, so congrats to him.
Originally Posted by zzombae
Tuned by Precision Dyno (Mustang Dyno)
TB Exhaust, drop-in Intake, MBC
whp/wtq
305/265
313/296
324/309
Thanks Nick 1,2..
and Edwin.. (how can I forget you)
whp/wtq
305/265
313/296
324/309
Thanks Nick 1,2..
Ok, have fun. The Evo and STi react the same way to all mods, and the turbos and IWGs are also the same, so be sure to do everything that worked on your buddy's STi.
Just FYI, the stock turbo on the STi is an IHI VF39 and the internal wastegate is terrible. It can barely bypass enough exhaust gases at stock boost levels, let alone with a slight boost increase or free flowing exhaust ... hence the boost creep problem. This is why an external wastegate can gain significant hp on the stock turbo'd STi ... it reduces the backpressure ...
The stock Evo turbo does not have this problem.
Originally Posted by 3000ways
Forget the EWG, just get a TBE, MBC, and Flash and your good. I hear (or read on another thread) that HKS will be releasing cams for the IX soon. They were displaying the cams at Sema.
