sputtering problem
Old Jan 9, 2006 | 11:52 AM
mr_one's Avatar
sputtering problem
i have a question whenever i slam on the gas (WOT) there gets a sputtering effect. i dont know if it is the plugs. so i am asking anyone if they have a suggestion as to what it could be. it feels like it isnt getting enough fuel....
Old Jan 9, 2006 | 11:55 AM
walkedu's Avatar
Did you buy the car used with all those mods or do them yourself? You make no mention of a reflash or stand alone. If you or someone else slaped all those upgrades on there with out a proper tune, that's your problem right there.
Old Jan 9, 2006 | 12:06 PM
4cdndctn's Avatar
If you list mods/tunes in order, it will help. Include when you change spark plugs
Ludikraut's Avatar
Read this thread: https://www.evolutionm.net/forums/sh...=177451&page=3
Smokedmustang just fixed a similar problem on his car.
l8r)
Old Jan 9, 2006 | 12:08 PM
Curt@MrLed's Avatar
Former Vendor
pull your plugs first..it could be a number of things.. we need more info to help you better..
Old Jan 9, 2006 | 01:27 PM
thebluesky's Avatar
Where are you located, and what's the weather like in your area? More importantly, has it been cold lately?
Old Jan 9, 2006 | 02:46 PM
mr_one's Avatar
sputter problem
i am located at lawton, ok. it's been hot and cold. i changed the spark plugs about a month ago. i got my power fc tuned at mzm performance. the problem just started happening. when i drive normal it is ok. when i hit the gas hard it starts sputtering picking up speed slowly.
Old Jan 9, 2006 | 02:53 PM
4WS Tuning's Avatar
i had a boost leak....and it did the same thing.....check ur vacuum lines to ur boost controller
Old Jan 10, 2006 | 09:55 AM
mr_one's Avatar
thanks
thans a lot ludikraut and everyone that gave insights. that forum u gave helped me out. it turned out to be the coil pack. thanks guys...
Old Jan 10, 2006 | 10:02 AM
AJsGenerX's Avatar
good... problem solved.
Old Jan 10, 2006 | 10:11 AM
mitsuorder's Avatar
When I have experienced this problem it has usually been due to a poor connection in between the plugs and wires. This was back when I was running aftermarket wires. You just can't beat the solid connection you get from the oem wires.
edit: oh and like smoked I repaired a few stripped out coil bolt holes in the valve cover but the problem still occured until I went back to stock wires.
Old Jan 10, 2006 | 03:43 PM
Ludikraut's Avatar
Rock on.
Time for a
l8r)
