20g-9 vs BB 50trim vs 3037 vs 3076
Originally Posted by Nez136
i was just thinking max power with good spool. 2.3 w/a 3076 would be a killer combo...and then add the alky
Originally Posted by Full-Race Geoff
dont mean to rain on your parade, but imo that is an awful comparison. There is very little to be taken away from those two plots.
-The turbine efficiency of the stage 3 wheel is dismal compared to that of the gt30R turbine wheel
-a PTE T3 Ford style 5 bolt housing is more on center than a garrett 4bolt housing, and will not flow as well
-a 50 trim bb uses a thrust washer/bb setup and is not as strong as a garrett ball bearing with no thrust washer
-the 76mm compressor map has much broader efficency islands than the 50 trim
the reason the 2.4 spooled so fast is that its a 2.4!!! there are so many variables in that test we can not really conclude much from it (ie turbine housing size, cam size, displacement, exhaust setups (maybe one had a cat) etc etc )
Geoff, you come from Honda camp where torqueless setups are the norm and acceptable. Your posts are gearing people to laggy setups. I hate lag and have had 10 turbos on my own car finding the best response.
I think I posed the question back on the first page about the 50 trim being called a 50 trim and received somewhat of an answer (thank you!) but I only asked hoping someone would realize that a 50 trim could be any one of hundreds of turbos. Trim only describes the relationship between the inducer and exducer. I'm just not understanding why we don't use the compressor's actual designation (60-1, GT28, whatever it actually is) because I still don't know what compressor the "50 trim" is! I get the whole T4 cold side mated to a T3 hot side. I saw someone mentioned a 76mm compressor but I'm not sure if that's inducer or exducer. Any info appreciated.
2.122" inducer
3.000" exducer
rated at 47 lbs/min
has a 78% efficiency island from 18-34 lb/min and from .5 to 1.5 bar boost. Very good compressor wheel based on older technology. Unlikely to outperform a more modern and more aerodynamic GT30R setup.
i think you should understand that when people talk about a 50 trim, they are referring to a t04e comrpessor wheel, 50 trim is the size.
2.122" inducer
3.000" exducer
rated at 47 lbs/min
2.122" inducer
3.000" exducer
rated at 47 lbs/min
Just from me parusing the dyno sheets and reading up on the subject, it seems 380-390 whp dynojet is just about the average for a GT30 on pump with the common upgrades (tbe, cams, etc). Yet, the Turbotrix 50 trim setup appears to be doing slightly better. They say most of their kits come in somewhere around 410-430 on pump. Now idk if its a dyno difference thing or what, but it seems that there is a trend emerging.
Going to race gas, the turbotrix turbo seems to push 470-490 like clockwork. I wouldnt say thats appreciably below GT30R rumbers on race gas, if at all. Now im not a turbotrix fanboy, and im not trying to push product here, im just trying to understand why a lot of tuners say the 50 trim isnt as good as a GT, yet a significant number of 50 trim cars a putting down awesome numbers, great spool, and swear by the thing.
Perhaps you (or anyone else) can comment? Much appreciated. Again, just trying to take in good info.
Is it possible that the turbo kits using this setup are not using very good manifolds, properly designed downpipes, etc.? Is it possible the tune was off? Is it possibel the turbo had the wrong turbine housing? Maybe the car had a cat?
There are a LOT of variable to consider when looking at overall power output. A power rating on pump gas is really worthless, as it depends on how much you are willing to risk the health of your motor? One guy who worked here ran 30 psi on 91 octane on his SR20DET. It ran great for 3 weeks, then he got some bad gas and melted 2 pistons.
I dont think there is a trend emerging here at all. I think that the data that is out there is very skewed and not at all indicative of any trend.
If you are only seeing 380-390, then i would say there are some serious discrepencies.
Fair enough, thanks for the input. That being said, do you feel that on the exact same setup, a GT3076R (with the hotside you prefer) should outperform the common ball bearing "50 trim" over the entire power curve? ... i.e makes more power sooner and holds more power longer...?
i agree with the fact that torque and response are wonderful, but to characterize me as that is a bit wrong. My 1.8L civic made 610 ft/lb of tq.
An average EVO with a 2.3 stroker making good power on a mid-large sized turbo makes full boost around 4500 with a 8000 redline (56%). This will be much more useable power and a pretty good all around car.
Beware - talking people into a turbo too big for their intended use will lead to unhappy customers and may even leave them for an unnecessary distaste for the import scene.
EVOlutionary
I have seen a dozen 20g turbo cars around here over the years. Over half died a very early death. Sorry this is just my observation.
The green is a 50trim/tdo6h turbo.
I would use a 50/stage3 in a pte housing over a gt3076.
here is a 2.4 with the new 50trim bb. http://www.srtforums.com/forums/show...3&page=1&pp=15
here is a nice graph of the 3076 on a 2.0 (laggy)
http://linux.forcedperformance.net/m...ctane_full.jpg
at 4500rpm the 50/2.4 is making 450whp.
at 4500rpm the 3076/2.0 is making 320whp.
have that diff is the turbo, the other half is the stroke.
I like a responsive turbo setup. Nothing better than instant torque.
the 3076 is capable of more power. if power is what your are after go with a 35r. its only a few hundred rpm laggier than 3076.
My 35r is setup to have very near the same spool as a stock evo8. Yet it makes 560+whp. FUN.
Ummmm How can you Compare the Neon to the Evo ? And a 50 Trim on a 2.4 of corse if going to make a ton more power sooner than a 2.0 thats why half these people stroke there motors. These two motors that your comparing are completely different from eachother. in no way shape or form is the SRT4 head a free following head like the Evos. and it certainly isnt on the same level. I speak from experiance i had a 50 Trim on my Srt4.
I just dont think your arguement is valid. your Comparing apples to oranges.
