GT3076R owners, post your #'s.
Old Feb 9, 2006 | 07:21 PM
  #46
WrX Kila's Avatar
Originally Posted by Mercenary3
evoviiiyou runns a FP 3065, which I beleive is very similar. 30r turbine with larger compressor than the usual 3076R-12.
In any event, he has a Switzer custom setup, but its nasty. 3076-12 like spool putting out 540 whp with very mild cams.
what fuel is he using and boost.
Old Feb 9, 2006 | 09:18 PM
  #47
TwStDeVo's Avatar
yeah i believe that gt3040(30r turbine, gt40 comp) is the same as the fp3065. this is what im looking for, but ive heard that its a mismatched turbo and that the 30r turbine cant flow the gt40comp well, but evoviiiyou has a nice set up!! so i dont know what to do. the other consideration is the 3076r with -13(not sure about the full specs and where it falls in the gt30r group). definitely looking for more help and info on these turbos. any recommendations?
Old Feb 9, 2006 | 10:07 PM
  #48
evoviiiyou's Avatar
Thanks for the kind words. She gets the job done...all though I wished I would have got the Leather package.
Old Feb 18, 2006 | 05:42 PM
  #49
thatsMR2u's Avatar
good info in this thread, for people like myself looking at the 30 series numbers!!
Old Mar 6, 2006 | 01:18 AM
  #50
FahKen Evo!'s Avatar
Damn so many variations on the GT30R, which is the proper way to get one, to make 500WHP on Meth.
Old Aug 4, 2007 | 11:52 AM
  #51
cutlass73's Avatar
Mods in sig.
Old Aug 20, 2007 | 07:44 AM
  #52
jazznevoluva's Avatar
Someone had asked earlier about a 3076r with a stroker motor. I have this setup with a 2.4 4g64 and 3076, so it is quite comparable. I was limited to 20 psi due to my injectors, and we dynoed in 108 degree scorching weather; so the numbers aren't all that high; but it will give you guys a good idea how the turbo spools. Very broad powerband.
Attached Thumbnails GT3076R owners, post your #'s.-3076_2.4_dyno_newjpeg.jpg
Old Aug 20, 2007 | 12:09 PM
  #53
EFIxMR's Avatar
I have the -13 GT30R and it is a sick pump gas turbo. On pump it will make over 400 whp DJ easily.
With racegas it will do 500 whp DJ without a problem.
However once you get to about 28-30 psi while the turbo will continue to make peak power but the power will fall off fast and has surge issues. For 500+whp I would pick a GT3040R.
Old May 21, 2008 | 08:14 PM
  #54
Crufty Dusty's Avatar
GT3076R on JUN 2.2L stroker, HKS 264 cams, 30 psi at 4400 RPM held. 98 RON (about 93 octane in the US). 100 deg F in the shade. Cylinder head is stock.
The new Nissan GTR does about 390 PS at wheels on this dyno.
Old May 21, 2008 | 09:37 PM
  #55
damstr's Avatar
evo9act made 445ish on CBRD's mustang dyno with pump gas 93 and 100% alky with the AMS 3076.
Got rid of that turbo though now has a hybrid which he loves sooo much better. Spools like a 30R with top end like power of a 35R.
Old May 22, 2008 | 06:40 AM
  #56
Guz Man's Avatar
432 whp with a GT3076R, with HFS-5 at 28psi
but then my stock block decided to take a dump and put cylinder 1 out of commission.. so i will be doing a full block build, and put it again on the dyno and see where it gets me...
Old May 22, 2008 | 11:01 AM
  #57
HaVoC RR's Avatar
30R's ROCK
Old May 22, 2008 | 11:11 AM
  #58
gamebred26's Avatar
mine is in the mail...
Old May 22, 2008 | 12:19 PM
  #59
Guz Man's Avatar
Originally Posted by NyC DrifteR
30R's ROCK
aimen to that...
Old May 22, 2008 | 12:21 PM
  #60
gamebred26's Avatar
what's the best 1/4 mile ET on one?
