Cam gears torque
Old May 17, 2006 | 06:54 PM
superman37r1's Avatar
A little bit of blue locktite will do the trick fo sho...
Old May 17, 2006 | 07:00 PM
EvilBlueEvo8's Avatar
Originally Posted by joeycoates
Wow, if you are going to respond to a thread, READ THE WHOLE THING! The main bolts that hold the cam gears onto the cams are torqued to 65 ft/lbs. The little screws that are on the cam gear itself, the ones that you must loosen to change the cam timing, are about 45 in/lbs. Or pretty hand tight, not put-your-weight-into-it tight. Also, use BLUE loctite, do not use red if you plan on ever adjusting them again....
exactly.
Old May 17, 2006 | 07:13 PM
TURBODAWG's Avatar
40 to 45 in lbs is the correct torque specs for the Fidanza cam gears. Other brands of cam gears may use different types of fasteners and will have there own torque specs. For those other than Fidanza, you should consult the manufacturer or the place of purchase.
And yes 65 ft lbs is correct for the retaining bolt that secures the cam gear to the camshaft.
Brian
Old May 17, 2006 | 07:20 PM
TTP Engineering's Avatar
Originally Posted by marksae
Damn, some people in this thread really need to work on their reading comprehension skills.
Holy crap...
Old May 17, 2006 | 08:24 PM
EVO8LTW's Avatar
I think my AEM cam gears had a sticker that said 15 ft lbs. for those bolts. Obviously, it depends on the brand of cam gears since different gears have different size bolts.
Old May 18, 2006 | 11:13 AM
mikiblueeyes's Avatar
Mine are tomeis and I would think 15ft/lbs would be realistic number for those, what do you guys think? I deffinatly dont want to break screws or undertorque them so the get loose.
Old May 18, 2006 | 11:53 AM
marksae's Avatar
Bolt torques are dependent on bolt and thread sizes. So the torque values on one cam gear may not work on another.
Personally, on small bolts, I just torque them by feel. Torque wrenches are not very accurate at lower torque values anyway and is actually somewhat dangerous cuz you can't feel it when you're stretching the bolt or stripping the thread. Just make sure you use blue loctite or equivalent thread locker.
Old May 18, 2006 | 11:58 AM
matt55's Avatar
Yes , yes i do . I went back and edited my 1st post , thanks guys for not letting this miss-info slip bye .
Evo9"Miss Rose"
Aug 16, 2008 08:49 AM
Noe18
15
Jan 4, 2008 02:51 PM
rulox 4g94
Lancer Engine Tech
Feb 21, 2007 10:41 AM
Mystery
33
Sep 10, 2005 11:40 AM
The Emperor
Aug 12, 2004 08:17 AM
