Damaged Rear Diff?
spider gears in the diff
edit- what type of noise are you hearing again a whine or a grumbling and are you sure its coming from the rear diff and not the TC
also if the front diff is making no noise and you dont feel a problem in your front you most likely dont have a problem.
I say this because if you know how a diff works, when you go into a turn, your spider gears start to turn so the outside wheel can turn faster then the indside wheel.it does this so the rear end of the car doesnt bind around the turn and since you said the fluid had silver in it I would guess that yes you do have a bad rear diff and it is the spider gears, but it also could be your carrier bearings in the diff
The only time I noticed a problem or produced any noise or bound up was when the car was warmed up sufficiently and I was turning. In a straight line: no noise, no binding.
Originally Posted by ICE888
Was it like you can coast the car, turn the wheel, and feel the rear inside wheel bind up, and then when you straighten it, it feels normal? What I mean is I can make the car bind, once I crank the wheel while coasting BUT when I straighten it again, it will be okay. I can make it bind, unbind, bind by just cranking the steering wheel. The more I think of it, the more I think the cetner diff might be involved.
Alfred
Alfred
i am getting the same thing after i changed fluid to redline i called ams and they told me it was normal because of the formula of the redline and the noise i was hearing was the LSD engaging.i can live with it
MODS
AMS I/C
AMS LICP
AMS CUSTOM FLASH
GSC 272
255 LPH
BLITZ OPEN TOP BOX
BLITZ SBC
SAMCO COLD AIR PIPE
APS TBE
319AWHP
290AWTQ
21PSI
93 OCT
MODS
AMS I/C
AMS LICP
AMS CUSTOM FLASH
GSC 272
255 LPH
BLITZ OPEN TOP BOX
BLITZ SBC
SAMCO COLD AIR PIPE
APS TBE
319AWHP
290AWTQ
21PSI
93 OCT
SyncdLancer
Sep 29, 2016 04:39 PM
Toxin
Jun 16, 2016 10:40 PM
CGroovy2k2
28
Nov 26, 2008 07:28 PM
QwikEVO
12
Sep 22, 2007 04:38 PM
