Better way to get 450 HP
Old Mar 14, 2006 | 04:24 PM
jid2's Avatar
I'm building a EVO 6 here in the states for someone right now. You already have the basic upgrades. I would say that you could use a fuel pump, big intercooler, and some intercooler piping to start. And make sure your exhaust is full 3 inch with no resonators.
For tuning you can't do AEM on a EVO 6 and have it be plug and play like the EVO 8. You would need the generic version and you would need to completely wire it in, which is no small task. Autronic makes a plug and play ECU for the EVO 6 though.
With all that you can upgrade your injectors and do a bigger turbo. At that point the choices are vast. HKS, or any of the US guys who do turbo kits. Do you want 450 on pump gas? If so what octane can you get?
Old Mar 15, 2006 | 10:57 AM
shinobi_30000's Avatar
I just bought my EVO IX, so I obviously have lots of questions. One is, what HP is the stock FMIC good for?
And my next question, (Sorry to get off topic) how do I get 350 HP, but still have room for expansion without having to replace parts again if I want to go higher.
Basically I want to modify my car, incremently increasing my HP/TQ. So what would be my first upgrade? Second upgrade? Third upgrade?
Etc.....
This is because I'm not Mr. Money Baggs and I can't spend 6 G's in one day.
All the help I could get would me much appritiated!
Thanx.
Old Mar 15, 2006 | 11:15 AM
FahKen Evo!'s Avatar
Etc.....
Thanx.
Basically you won't need an upgrade until a larger turbo. The EvoFQ400 with the HKS turbo still runs the stock FMIC. You figure it is good till 400WHP.
Old Mar 15, 2006 | 11:23 AM
So what would the the first upgrade that I could do that would yield the most gain?
Old Mar 15, 2006 | 11:26 AM
It is just ONE mod but a combination. If you have an Evo IX, then your first set of mods should be this.
Full 3.0 Turbo Back Exhaust
Cheapo eBay 02 Housing
Hallman or Forge MBC
Boost Gauge
ECUTEK Tune, that will net you 80WHP gain. After that you need to worry about your clutch going. with those mods you will NOT BELIEVE it is the same car.
Old Mar 15, 2006 | 11:32 AM
Boost Gauge
Nice, so tell me about the housing? I don't know what that is.
Old Mar 15, 2006 | 11:56 AM
Go to ebay and seach for a Evolution 02 housing, they are all the same and work very well.
Old Mar 15, 2006 | 12:23 PM
What exacltly is it used for though?
Old Mar 15, 2006 | 12:48 PM
http://cgi.ebay.com/ebaymotors/Lance...QQcmdZViewItem
Very simple and inexpensive piece that removes a lot of back pressure that the stuck unit clogs up. Improves spool as well. VERY cheap, get one.
But don't use their sh1ty gaskets, get an OEM gasket or reuse your stock ones.
Old Mar 15, 2006 | 01:29 PM
Any issues with this setup? Besides the clutch gonig out much faster, everything should hold?
Old Mar 15, 2006 | 01:35 PM
triple6's Avatar
what kinda pwer can you get out of that gt42r??
Old Mar 15, 2006 | 02:00 PM
You would need a built everything before even thinking of that turbo. 900++++WHP. Keep your stock turbo for a while, it is VERY good.
Old Mar 22, 2006 | 02:20 AM
triple6's Avatar
hmmmmm i think i have a new goal in life.
Old Mar 22, 2006 | 02:38 AM
streetturbo's Avatar
I would go with:
- walbro 255 l/h fuel pump
- drop in hf filter (k&n, etc)
- 3 inch turbo back with hf cat or test pipe
- mbc (hallman or forge)
- good reflash
- licp (ams) & o2 housing (ebay) for faster spool up
- boost gauge
This package is good for over 400 hp (not whp), it means you again around 100 hp over stock. For complete safety i would buy also apr head studs and rod bolts.
The stock clutch won't be good for a long period so consider Act or some other oganic clutch with good street driveability.
Take care and have fun with the IX!
hermesevo8
Sep 10, 2015 10:50 AM
03EvilEvoWhite
18
Sep 5, 2013 09:02 AM
EvoDom
33
Mar 5, 2009 04:12 PM
sleeperevo8
14
Dec 4, 2005 03:08 AM
crazy_evo414
14
Aug 18, 2003 04:35 PM
