Walbro pump failure?
Old Mar 10, 2006 | 09:11 PM
MYEVOVIII's Avatar
I say for the money these cost and if where my Evo I would buy a new one just to be on the safe side. Good luck!
Old Mar 10, 2006 | 09:37 PM
Zeus's Avatar
I paid the big money for the PE Denso 210lph pump because I killed two Walbros. They got louder and louder with pressure starting to fluctuate at full boil. The Denso has been freakin great! I paid a little over $200 for it. BTW the PE 255 pump is just a Walbro
Old Mar 10, 2006 | 10:38 PM
Danny23's Avatar
My Walbro Made Noise For 21k Miles, Never A Problem With It
Old Mar 11, 2006 | 07:34 AM
LuxuryBroker's Avatar
doesn't denso make a 310 fuel pump for the evo?
Old Mar 11, 2006 | 08:16 AM
pinkparrot's Avatar
Originally Posted by MrFairlady
ok break me down....whats the smart upgrade?
http://www.vishnutuning.com/evo_XEDE_SMART
there u go buddy, for the guy that asked
Old Sep 7, 2006 | 08:59 PM
mrfred's Avatar
Do you know the PN for that Denso 210 lph pump or where I can get one?
Old Sep 8, 2006 | 12:24 AM
sparky's Avatar
My Walbro changed the pitch of its whine when I went to an XEDE map that had a too rich fuel table. The sound changed back to normal, once I switched back to the old map. I guess that the richer map caused the pump to switch into its higher voltage mode. Go figure!
The Denso Supra pump though of a higher quality than the Walbro, better flowing and quieter running, is not plug and play as I understand it. There is a Buschur Racing high output intank replacement pump however.
Old Sep 8, 2006 | 11:28 AM
GTVEVO's Avatar
I also killed a walbro last month, by the time I made it home my car was running mid 16s- mid 17s AFR. Got home and pulled the FPR hose off and pressure only went up by 2psi and it was running lower than normal pressures even with the hose connected. The bad thing is it wouldn't start acting up until the pump was good and warmed up about 10min of the car running so that made for a fun trip home.
Looks like the denso pump would be a very good replacement and pay for itself!
Old Oct 10, 2006 | 02:48 AM
trinydex's Avatar
do they?
Old Oct 10, 2006 | 06:28 AM
MR Dan's Avatar
you have a part # for that Denso pump?
Old Oct 10, 2006 | 07:13 AM
EVONation's Avatar
Everyone recommends that you get this Pump if you get the ECU flashed now after reading this is it REALLY worth getting? Should I keep stock?
Old Oct 10, 2006 | 08:17 AM
MR Dan's Avatar
if you dont have a flash, a FP is not necessary
mrfred
68
Jul 13, 2017 11:22 AM
ReivaXVrai2
Sep 30, 2015 12:42 PM
rs03evo
Apr 25, 2014 06:13 AM
wewtRallywewt
20
Aug 2, 2012 12:29 PM
richie rich
Nov 22, 2011 12:03 PM
