is my clutch ok?
Old Mar 23, 2006 | 07:13 PM
E VOL IX's Avatar
is my clutch ok?
I went racing the other night in my IX.. Made 3 passes and only got 5500 miles on my car. My clutch was slipping a lil bit on the way home... Im not gonns drive it for the next two days till i get dynoflashed. Will my clutch be alright after it cools down???
Old Mar 23, 2006 | 07:17 PM
Greg K's Avatar
it depends on how bad you glazed it. If it's really bad I recommend against getting flashed because that will only make matters worse.
Old Mar 23, 2006 | 07:46 PM
Ultimate CC's Avatar
yea it all depends on how bad you glazed it....
Old Mar 23, 2006 | 08:03 PM
E VOL IX's Avatar
well its never slipped before.. I think it was just real hot because i ran all within like 15-20 min with little cool down.. Im sure it will be fine after i let it sit for 2 days
Old Mar 23, 2006 | 09:12 PM
Danny23's Avatar
SHOULD NOT BE SLIPPING ON THE RIDE HOME, i THINK YOU MIGHT HAVE FRIED IT,HOPE NOT GOOD LUCK
Old Mar 23, 2006 | 09:19 PM
JSYEVO's Avatar
thats what happened to me, it just gets worse. if you are really set on getting dynoflahsed, i would not go near wot till you do.
Old Mar 24, 2006 | 08:05 AM
ACTman's Avatar
It is toast. The clutch should mostly recover in a manner of a minute or two. My guess is that you cooked the material off and warped the flywheel to the point where you are now on the stops that won't allow the pressure plate to grab any longer. If that is the case, you will be slipping like mad in no time at all. It is not a gradual decline as it is with most cars.
Old Mar 24, 2006 | 02:16 PM
Evo_Jay's Avatar
You need to test it by hammering the gas at about 3500-4000RPMS and see if it slips. I don't know what gear you should use, but Warr does.
Old Mar 24, 2006 | 02:24 PM
Warrtalon's Avatar
Top gear, which provides the most load. Start at 3k rpm, though.
I doubt the clutch is fine. My ACT started slipping in 5th/6th gear on the way home from my last track event, and now a week later, I can't even boost in 2nd gear. Time for an Exedy!
Old Mar 24, 2006 | 02:38 PM
ACTman's Avatar
Traitor! Just kidding.
I would like to check out that clutch and flywheel when it comes out if you don't mind since you have already given so much feedback on it. Can you send it to me?
Old Mar 24, 2006 | 03:01 PM
Warrtalon's Avatar
I can send it to you if you provide me an address and payment info. Should I just send COD?
For the record, here is what the clutch endured and how long it lasted:
- 9500 miles
- 9 months
- 100+ drag strip launches (5500rpm+)
- 90% of those launches were 1.75 60' or better and 12.3s ETs or better with 108mph or better
- 40+ autocross runs (90% were full drag launches)
- 250mins of full bore road course action
- required three adjustments, the first was 2 months after installation when I could no longer shift at 7k rpm, the 2nd was 5 months later when it happened again, then the 3rd was about a month ago, which put me right at the end of the clutch rod - after that, it started slipping
I assume both the disk and my stock flywheel (replaced along with the clutch) are both completely destroyed.
Old Mar 24, 2006 | 03:22 PM
ACTman's Avatar
- 9500 miles
- 9 months
So we can get the best estimate of what it looks like, don't slip the hell out of it before you get it out. I would wager that the pressure plate and flywheel are pretty warped which is why you needed further adjustment. We found that was true on others we tested. The travel to release was great on the bench but the warpage caused it to require more travel when spinning. When the surfaces are flat and uniform, the pressure plate is able to lift more cleanly if that makes sense.
If you don't mind, send as much data as you can with the parts since you obviously have it. What about the restrictor? Were you using it or not or for how long? Many Thanks!
Old Mar 24, 2006 | 03:27 PM
Warrtalon's Avatar
Sorry, it's been slipped to death for the last week and a half, so too late for that.
No restrictor valve since the initial adjustment at the 2-month mark, which is when I also installed a SS clutch line. My power has changed dramatically since then, too. I'm probably at an extra 70whp/100wtq now.
Shipping address and shipping payment info?
Old Mar 24, 2006 | 04:29 PM
ACTman's Avatar
PM sent.
GSX 911
Sep 23, 2013 05:43 AM
dizzle06ix
20
Sep 19, 2011 08:24 AM
dsmdeliveryboy
11
Jun 21, 2008 08:11 AM
1BlackEvo9
49
Nov 16, 2006 08:48 AM
ant_turbo
21
Sep 14, 2006 11:42 PM
