CEL code after mods/tuning
Old Mar 24, 2006 | 07:39 AM
LilJapnBoy's Avatar
I am currently pulling a P0138 code (Heated Oxygen Sensor Circuit High Voltage; Bank 1 Sensor 2).
Background:
  • Last week got work done including cams, porting/coating manifold, o2 housing, and hotside.
  • Tuned at the end of the week.
  • Picked up the car and did a test ride, ran fine, no codes.
  • Stopped car, started car 20 min later and drove home.
  • Threw SES light right away.
  • Have reset 2 additional times with same results after second restart.
According to my research, this is the 2nd sensor located off the midpipe, NOT the one off the o2 housing?
Anyone with some insight on why this is being triggered and possible solutions? Has anyone experienced this after porting exhaust parts? Or after installing cams?
Yes, I do run a test pipe with mechanical fix (oxygen bung) and I do NOT believe that is the problem since I've been running code free for the past 2 years.
Thanks in advance.
Old Mar 24, 2006 | 08:22 AM
3000ways's Avatar
bump
Old Mar 24, 2006 | 08:26 AM
sirloin1219's Avatar
how do you guys know what codes are what and how do you scan for it?
Old Mar 24, 2006 | 08:39 AM
boomn29's Avatar
Autozone sells OBDII pullers. I picked up one for like $80.
Old Mar 24, 2006 | 06:50 PM
LilJapnBoy's Avatar
Bump since the only replies I've gotten were OFFTOPIC.
Where's the gurus at!?!
Old Mar 24, 2006 | 07:46 PM
mikiblueeyes's Avatar
when they been working on your o2 mani, they probably had exaust hang on the o2 sensor for lil bit. Ithink wire is broke, try to swap sensor with anotherone to see if it'll fix it. But most likely its the reason.
Piece
Old Mar 27, 2006 | 05:42 AM
LilJapnBoy's Avatar
bump for some NEW ideas?
Old Mar 27, 2006 | 05:52 AM
ashton13's Avatar
Did you talk to the shops that did this work to see if they had any ideas on the matter?
Old Mar 27, 2006 | 06:54 AM
bigfishs's Avatar
Buy a new rear o2 sensor (~100 bucks) and install it. If it goes away, the sensor was fooked. If it doesnt, then you will need to invest in an electric O2 fix (eg perrrin).
It is a really grey area as to why these codes keep popping up, no one ever seems to have a real answer as to why it occurs.
As far as I know, there is no other way to tell what is going on, altough some fancy OBD2 readers may let you look at the waveform that the sensor is sending to the ecu.
Old Mar 27, 2006 | 09:43 AM
brooks1005's Avatar
I was getting codes after the cat-del install.Installed mech fix and still getting codes.Pulled out the o2 and wiped off the black gunk and found a slice in the wires.Replaced it and no more codes!Anything on the road could bounch up and slice those wires.
Old Mar 27, 2006 | 12:25 PM
LilJapnBoy's Avatar
Thanks for the replies.
I wanted to go to Buschur after I got some feedback to perhaps pinpoint the issue down a little more.
Al initially pulled the code and said it was a my front O2 sensor and I had a bad front O2 sensor. Go figure.
I will have to get the car up on a lift and confirm the wiring as well as the integrity of the O2 sensor. I have never had a problem with a dirty O2 since I'm running the oxygen bung off the test pipe.
I'm just surprised because I ran fine before I took the car into the shop. The work done shouldn't have impacted the rear O2 sensor, maybe front O2 sensor when they swapped the O2 housing.
tephra
Sep 13, 2021 01:07 AM
GraphiteEvo9
For Sale - Cars For Sale
Sep 5, 2015 12:09 PM
supak1111
Mar 23, 2012 01:57 PM
ILLTechAuto
Aug 21, 2008 02:22 PM
philippine_evos
Aug 25, 2004 05:28 AM
