Trans or Tcase
Old Mar 26, 2006 | 05:34 PM
FLAEVO's Avatar
Trans or Tcase
Went to pull in to my driveway turned to the right going slow car stoped
felt like it was binding.Backed up and went forward it seamed ok until I turned
the wheel then it locked up again.I took the left front axel out this morning
and took upper cv joint apart everthing look good .The clips and needle
bearings all looked fine. So what do you think trans or tcase.The car has
62000 mls. on it,I have agt35r with meth triple carbon clutch I do not
do hard launchs with it .The gt35r has been on the motor for 15000 mls
it is a 03 evo
Old Mar 26, 2006 | 05:36 PM
smokedmustang's Avatar
Transfer case (I mean differential) or the rear diff. not trans related in my opinion. Good luck bro!
Old Mar 26, 2006 | 05:49 PM
elhalisf's Avatar
i agree. mostly likely the front differential in the t-case.
Old Mar 26, 2006 | 06:07 PM
Old Mar 26, 2006 | 06:17 PM
FLAEVO's Avatar
I will be calling Shep tomorrow to find out about rebuild and quaife.I hope turn around
is not to long.It looks like I am still getting my ducks in a row for my summer stroker.
Old Mar 26, 2006 | 06:40 PM
elhalisf's Avatar
try TRE www.teamrip.com
i just got my tranny and t-case rebuilt by them.
Old Mar 26, 2006 | 06:43 PM
jmartinez1170's Avatar
same here works great.
Old Mar 27, 2006 | 02:35 AM
Got the TRE also! Great stuff.
Old Mar 27, 2006 | 02:07 PM
FLAEVO's Avatar
How did long did it take and was anything else wrong in side the tcase.
Old Mar 27, 2006 | 03:19 PM
EVOlutionary's Avatar
On my tcase the ring gear had some micro cracks in about 4 or 5 of the teeth. I had to replace the whole TCase at about $1800. Plus I had a Quaife front LSD installed at $1500. So about $3200 is your worst case scenario. Assuming the ring and pinion is OK, just to reprofile those and install an LSD (stock cast spider gears probably broke) is maybe $400 plus the LSD.
EVOlutionary
Old Mar 27, 2006 | 04:35 PM
Jon is quick, they send the "box" to put your TC in, postage paid to him, then he will fix and return it, I have the forged spider gears (Jon hasn't seen one break yet), and it cost me 1500 or so TOTAL!
fireroasted
Mar 22, 2013 04:28 PM
CtSilver03Evo
18
Aug 2, 2011 06:41 AM
Flyin EVO 2
Aug 28, 2010 10:18 AM
DOUGLAS
Aug 30, 2009 08:43 AM
elhalisf
Sep 22, 2006 10:57 AM
