How to install a Greddy Type-S By Pass Valve
Old Apr 6, 2006 | 07:19 PM
lagcisco's Avatar
Would anyone happen to know how to install a Greddy Type-S BPV?
I has two nipples but my stock BOV only has 1 nipple so I'm unsure where the 2nd one would be connected to, attached is a pic of the BPV
Old Apr 6, 2006 | 07:27 PM
lagcisco's Avatar
heres the pic
Old Apr 6, 2006 | 07:41 PM
Evoryder's Avatar
little nervous for you... however, too nipples is normal...i'd worry if you only had one....as far as your bov use the top nipple...not the lower angled one...
make sure the bov is in the correct position...bottom of bov to charge pipe and front to recirculate back into intake tract. lmk if u got any more Q's
Old Apr 6, 2006 | 07:47 PM
trinydex's Avatar
i fyou wanna use both nipples get hte dejon tools leak stop kit.
Old Apr 7, 2006 | 12:59 AM
lagcisco's Avatar
thanks for the pic, my attachment didnt work for some reason
why would I want to use both nipples?
Old Apr 7, 2006 | 01:02 AM
trinydex's Avatar
cuz you can hold all the boost you can throw at it and vent as easy as pie.
the greddy type s is the only bov that is presetup to do this. hence why in my opinion it is the best valve made. of course i run a modified 1g dsm valve that does the same thing.
basically what the dejon tools leak stop kit is, is ia pnumatic switch. on boost it redirects all air up to the top of the diaphram closing it tight.
off boost it punches air under the diaphram to open it (bottom nipple).
case closed
Old Apr 7, 2006 | 01:03 AM
tony_b's Avatar
You can just plug the bottom one. If you have any surging issues, connect the bottom one to a boost source to help blow it open.
Old Apr 7, 2006 | 01:04 AM
trinydex's Avatar
VERY GOOD, boost source... not vac source... say no to the single spring mod.
Old Apr 7, 2006 | 01:12 AM
lagcisco's Avatar
hmm, I think my BOV has the single spring mod, going to have to check with the previous owner
Old Apr 7, 2006 | 01:25 AM
lagcisco's Avatar
ok it looks like I do in fact have the single spring mod so I dont need the leak stop fix and I dont need to connect the lower nipple to boost source
just a simple cap on the lower nipple and that should be it right?
would it be worth while getting the spring that was in there and using the leak stop fix?
Old Apr 7, 2006 | 04:16 AM
Evoryder's Avatar
my car runs great with the single spring adjusted.
Old Apr 7, 2006 | 06:30 AM
ibanez_926's Avatar
When i had that valve i used the single spring mod and left the bottom nipple open. Held boost great and had no drivability issues.
Old Apr 7, 2006 | 01:41 PM
trinydex's Avatar
see that's the thing... it may work for some... but it also may not work for others. it was not the way the valve was meant to be run.
2StepsAhead
11
May 9, 2010 08:37 AM
jasonn
Oct 13, 2005 01:05 PM
mobounce
19
Apr 15, 2005 09:36 AM
zyounker
24
Apr 4, 2005 04:13 PM
hel_if_ino
13
Aug 20, 2003 04:57 PM
