Pulling the engine
Old Apr 18, 2006 | 07:52 PM
althemean's Avatar
Pulling the engine
For those that have done this. Are you dropping the tranny first?
Thanks
Old Apr 18, 2006 | 08:13 PM
elhalisf's Avatar
no.
i took it out with tranny and t-case . it is kinda tricky by very duable.
Old Apr 18, 2006 | 08:29 PM
althemean's Avatar
So I can actually seperate the tranny from the t-case and pull out the engine/tranny assembly as one unit. To do this I still need to disconnect the driveshaft on the RH side right?
I have the service manual but I want to know what others have done as it says to remove the TC and tranny completely before pulling the engine. This seems unnecessary to me.
Old Apr 18, 2006 | 08:41 PM
Noogles's Avatar
i disconnected it form the t-case and pulled it up as one assembly.
Old Apr 18, 2006 | 08:47 PM
gogoevo's Avatar
pull the halfaxles and driveshaft and your ready to go, mines gone in and out many times motor tranny tc all together
Old Apr 18, 2006 | 08:49 PM
althemean's Avatar
when you did that, did you disconnect any of the axles/driveshafts/input shafts of any sort?
Old Apr 18, 2006 | 09:11 PM
elhalisf's Avatar
just the axles and driveshafts. not the input shafts
the TRICKY TRICKY part it getting it out on an angle. the bottom of the engine (crank pulley) must first clear the passenger side rail before the trans starts to move up. ALSO, you have to move the engine away from the car as you are lifting it up, where the t-case is on a 45 degree angle. .
Old Apr 18, 2006 | 09:28 PM
althemean's Avatar
what about doing your method and leaving the TC in the car? I have no reason to remove it. I assume in doing this I would also have to remove the input shaft then? What advantage am I getting by removing the TC along with everything else?
Old Apr 18, 2006 | 09:55 PM
elhalisf's Avatar
ok, i think i got you alittle confused. or maybe i am, lol
i removed the engine, trans and tcase all still attached together. i did not seperate any of them. i only remove the L/R axles and the driveshaft. you dont have to remove the 2 small shafts that go inside the tcase and tranny, which are called the input shafts.
the only advantage of removing the t-case and tranny before the engine pull is that it will be easier to pull out the engine. but your probably gonna spend 3-4 hrs removing that stuff instead of an extra 15-45 min trying to remove the entire assembly as one.
Old Apr 19, 2006 | 06:00 AM
althemean's Avatar
I think I follow you now. I cant leave the t-case in because there will be no support for it right? The T-case HAS to come out. So I remove the axles and driveshaft to disconnect the entire driveline ***'y from the car body, disconnect all the wiring and hoses, undo the mounts and out it comes, its just a bit of a manuevering process after that.
I am right at that point right now. I was just gonna pull the heads and do an in chassis swap, but I am so close to pulling the engine, I figured, do it to make things easier on me later on (mainly my timing belt) then I get the excuse to replace the clutch as well.
Old Apr 19, 2006 | 07:42 AM
elhalisf's Avatar
no, t-case does not come out. the 6 bolts that support the t-case are still going to be attached to the trans, so there is plenty of support. plus, its is VERY difficult to remove the t-case out of the car without removing the trans.
and remember, remove the engine/trans/t-case assembly almost sideways.
Old Apr 19, 2006 | 07:43 AM
Torre from Va.'s Avatar
We dropped the t/case first, and the motor/tranny together.
Old Apr 19, 2006 | 08:16 AM
Ev0ikon's Avatar
Sounds like you take the TC from the bottom and the Engine+Tranny through the top?
Can you please gimme a quick run down on how to drop the TC from the bottom?
TIA
Old Apr 19, 2006 | 08:59 AM
althemean's Avatar
this was the method I was thinking of doing. Still have to pull the driveshafts and I am pretty sure the service manual says to pull the input shafts as well.
To pull the driveshafts I need a slide hammer right?
Old Apr 19, 2006 | 09:13 AM
elhalisf's Avatar
lets get some terminogoly straight here
the driveshaft is the big long peice that goes from the t-case to the rear end. that peice simply slides off the t-case
the axles are the 2 left/right peices that attach the tcase to the wheel hubs. those are secured by snap rings, which can simply be popped off using a crow bar.
the 2 half shafts are the small rods that go inside the t-case and trans, which are also secured by snap rings, but need a slide hammer to be popped off.
