Invidia Cast O2 Housing (pics)
Old Apr 29, 2006 | 07:43 AM
  #61
GreddyEvo's Avatar
Put me on the list, I'm in for sure!
Old Apr 29, 2006 | 08:27 AM
  #62
FSUevodude's Avatar
Another difference between the Works o2 housing and the Invidia is that the Invidia separates the gas flow from the wastegate from the air coming out ot the turbine with the wall inbetween the two holes in the bottom of the housing. This "should" make more power by mixing the two flows further down the exhaust stream. The support bracket should help more with aftermarket tubular manifolds from creeping and eventually cracking than it would with the longevity of the housing itself. Hope this isn't entirely off topic, but just a few observations.
Old Apr 30, 2006 | 08:48 AM
  #63
BoOsTinGEVO190's Avatar
would this fit on any downpipe unlike the works alot of people are having problems??
Old Apr 30, 2006 | 09:33 AM
  #64
kimletrim's Avatar
Registered User
Interesting observation.
It should work with most downpipes that use the stock donut gasket. I had a little trouble using the the provided donut gasket because I have the WORKS downpipe, but I modified the stock donut gasket so it would work with the WORKS downpipe. I don't think it will be much of a problem for other brand downpipes using a donut gasket.
The vendor I bought it from said that Invidia unit would also work with the stock downpipe.
Old Apr 30, 2006 | 09:36 AM
  #65
J8dailo's Avatar
did the invidia exhaust manifold ever come in production???
Old Apr 30, 2006 | 06:41 PM
  #66
EvoRacer619's Avatar
wow looks good! cant wait to get mine
Old Apr 30, 2006 | 08:29 PM
  #67
86gti's Avatar
little pricey.. but looks like it would work well
Old Apr 30, 2006 | 09:22 PM
  #68
kimletrim's Avatar
Registered User
Pricey? It's less than half the cost of the WORKS unit. Just look at what you get compared to the ebay housings.
Old May 1, 2006 | 07:03 AM
  #69
InjectedPerformance's Avatar
I was told it is coming out very shortly.
Old May 1, 2006 | 02:43 PM
  #70
Aby@MIL.SPEC's Avatar
That looks nice
Now you need to get rid of that pos compressor discharge tube & put something on there that doesnt neck down to 1.556" from 1.7" i.d.
Old May 1, 2006 | 02:45 PM
  #71
turbo xs made some early dp's to be used with 3" donut gaskets.
buy 1 of those for ~$175 & you'll be set @ the fraction of the cost of a works piece.
Old May 1, 2006 | 03:08 PM
  #72
kimletrim's Avatar
Registered User
Originally Posted by WOT
That looks nice
Would you happen to have a suitable replacement for the discharge tube Abby?
At the moment I am still using the stock Evo 8 discharge tube and it is too tight of a fit for my liking.
Old May 2, 2006 | 08:33 AM
  #73
evo ippo's Avatar
yeah i order mine from Marty over at injected yesterday he said they should come in today and shipping it out today. Marty was awsome he hooked it up with a DC manifold and the Invidia O2 housing, Very good service!!!!
Old May 2, 2006 | 09:43 AM
  #74
milo's Avatar
This is the same setup I want to run on my EVO 9 MR. Keep my updated in your install
Old May 2, 2006 | 11:32 AM
  #75
BlueFastEvoVIII's Avatar
that thing looks nice
