Evo VII Boost !!
Old Apr 30, 2006 | 05:23 PM
Devil_Evo's Avatar
Question Evo VII Boost !!
Hi all
what's the Evo 7 Boost?????????
Is it same as evo 8 or not???????
and does anyone know for sure when the ECU in the Evo VII cuts out?
Old Apr 30, 2006 | 06:03 PM
funnyclub's Avatar
Originally Posted by Devil_Evo
Hi all
I think standard boost is 1.2-1.3 bar and fuel cut is just over 1.5 bar.
Old May 1, 2006 | 01:33 AM
Devil_Evo's Avatar
where are you guys ?
please help
Old May 1, 2006 | 01:48 AM
Waz996's Avatar
Mine was japanese boosted at 19 to 20psi and then after some while it started dropping but i gues it was just a bad cheap guage
wael
Old May 1, 2006 | 03:51 AM
hashash's Avatar
my blitz boost gauge showed 1.2 bars when my car was standard-ish
Old May 1, 2006 | 04:04 AM
4age's Avatar
It should be 1.2 Bar and goes down to 1.1 at higher revs. Fuel Cut ist somewhere about 1.4 / 1.5 Bar.
Old May 1, 2006 | 06:01 AM
AhmadHasib's Avatar
Fuel cut meaning the fuel stops going to the engine, or the fuel pump isnt sufficent enough for that much boost so it just runs incredibly lean?
Old May 1, 2006 | 09:19 AM
Oli's Avatar
Oli
the ecu cuts fuel to stop any damage from too much boost
Old May 1, 2006 | 11:08 AM
11secEVO7's Avatar
stock mine was running 20psi....
with just exhaust.
Old May 1, 2006 | 12:54 PM
Devil_Evo's Avatar
Thank you guys for replys
I just bought these parts ..waiting to install :
1- Blitz NUR Spec R Cat Back.((there is no hole for the Oxygen Sensor > Is it important to install it or not?coz the exhaust is for the JDM Spec evo and JDM Spec Evos has no Oxygen sensor in the cat back))
2- Fujitsubo Downpipe.
3- Helix Cat Delete.
4- A'PEXI Boost Gauge.
5- Hallman MBC.
I'm planning to increase boost to 1.4 or 1.5 BAR with the stock ECU ... do i need Fuel pump,Fuel Regulator, HKS FCD,,,etc ???
what do i need to run 1.4 or 1.5 without detonation at all?????
Old May 1, 2006 | 01:11 PM
11secEVO7's Avatar
probably just the fuel pump to be on the safe side.
injectors should be more than sufficient.
my evo 7's stock ecu allowed me to boost up to 24psi before cutting.
also 1.5 bar aint that much...i would boost 20psi stock and at night it would spike to 21psi. so you should be very safe.
genesisevo
Apr 1, 2014 01:37 AM
turbooutlaw1976
Oct 6, 2013 09:37 AM
Rex.lao
11
Sep 17, 2013 10:23 AM
Trini7
23
Mar 30, 2007 11:51 PM
s4awd
Jan 14, 2003 06:17 AM
