engine compartment temperature
Old May 8, 2006 | 04:56 AM
Derek888's Avatar
any idea whats the average temp under that hood?
Old May 8, 2006 | 05:09 AM
Ph3n1x's Avatar
Id take a guess of 150 Fareheit.
Best bet would be to use a thermonmeter i guess.
Old May 8, 2006 | 05:18 AM
Derek888's Avatar
someone said its about 350-400F. just want to confirm
Old May 8, 2006 | 05:21 AM
Ph3n1x's Avatar
I dont think its that high when the hood is popped. Just put a thermometer there for a few minutes and you ll know for sure.
Old May 8, 2006 | 05:22 AM
Ted B's Avatar
Underhood temperatures are at their highest when the car is idling at a stop. Once the car starts moving from a stop, underhood temperatures drop. In my Taurus SHO, we found that underhood temps approached ambient once the car reached ~30mph (~50kmh).
Old May 8, 2006 | 05:45 AM
Derek888's Avatar
i dont have a thermometer so any idea how hot it gets during idle?
Old May 8, 2006 | 05:47 AM
Ted B's Avatar
Hot enough to cook a chicken.
Old May 8, 2006 | 06:00 AM
Derek888's Avatar
yes i know its hot but I need to know the numbers
Old May 8, 2006 | 06:16 AM
nothere's Avatar
what part of the engine bay?, sounds like you want to install something. the front head light area =cool, try touching the tower bar after a hard run, pretty hot, the block, hotter still.
if you need to install somerthing the coolest area would be the drivers side area under the headlight. I am guessing it will never see 150+, untill you have a thermal event.
Old May 8, 2006 | 08:49 AM
Derek888's Avatar
right above the engine in front of the strut bar... like the spark plug cover
Old May 8, 2006 | 02:36 PM
Aby@MIL.SPEC's Avatar
Amb. Temps / Water hose area near bov / Air Box-Headlight area
30 / 58 / 35
37 / 63 / 43
42 / 68 / 49
44 / 72 / 50
I measured this a while back, temps are in celsius, used an exposed junction k-type thermal couple
temps were measured when traveling ~35mph
Old May 8, 2006 | 10:27 PM
Derek888's Avatar
thanks!
