Hard to shift.
Originally Posted by evoleye
The only thing I have is that on idle or when the car is cold it won't go in gear as easy.
I have the SS clutch line and restrictor pill removed. I've also tried just about every different adjustment possible with the clutch pedal and have bleed the system dozens of times. I think its just a problem with the twin disk.
05 Evo8 9k miles 4th-5th gear syncro went out I was like wtf...I dont even get crazy with the evo or anything yet...I have not even launched it or taken it to the track...I dont force shift it...I had it replaced under warrenty...
use BG syncroshift in the trans., diaqueen in the t/c and diff.. had the 4th gear grind in my 03 and t/c whine, i used redline in the whole driveline and after three months thats when everything starting going on me. everything replaced under warranty. DONT use redline in evo,s everyone i know that did had the same problem after a while. like i said BG in trans., diaqueen in t/c and diff.
it is hot out here. And so far no problem.
So far I poured a bottle of friction from Mitsu and I adjusted the clutch a little. And so far it is getting better. I also noticed that I adjusted a little closer to the specs that the book calls for. Meaning the pedal is closer to the firewall. I'll try to adjust it to the exact measurements and see the results.
