resonated test pipe vs test pipe (HP difference)
Old Jun 4, 2006 | 01:57 AM
5k6's Avatar
5k6
Question resonated test pipe vs test pipe (HP difference)
I searched and did not find a definite answer. Is there a HP difference between a resonated test pipe and a test pipe? I have a HFC and want to know what I should go with.
Old Jun 4, 2006 | 10:03 AM
fsugatorbait's Avatar
If the resonated test pipe doesnt taper than there is no difference.
Old Jun 4, 2006 | 02:29 PM
Zeus's Avatar
I've not seen a difference with the Megan resonated delete pipe vs straight... however, it has no taper, and is perforated in the proper direction (away from flow).
BTW It's not a shameless plug... I don't sell them separate, and Megan is out until mid to late this month... I think.
Old Jun 4, 2006 | 09:49 PM
5k6's Avatar
5k6
btw zeus will the megan catback fit the IX?
Old Jun 4, 2006 | 09:58 PM
fromWRXtoEVO's Avatar
I personally have a collection of all: two 3"HFC, one resonator test pipe and one straight test pipe.The resonator test pipe can almost flow as much as a test pipe but the main two handicaps to this matter is that the some resonator test pipes have smaller diameter and also the resonator cavity disturb the flow a bit.
This is just my observation. As far is performance go, this is how I personally would categorize:
cat delete straight trhough the most boost and flow
resonator cat delete lesser flow but still better than a HFC
3" HFC good flow but slows down spool up and boost
my .2c
Carlos
Old Jun 5, 2006 | 04:33 PM
shbomb8188's Avatar
does megan's resonated test pipe fit all aftermarket cat-backs and dp's or just megan parts?
Old Jun 5, 2006 | 04:41 PM
Warrtalon's Avatar
It fits pretty much everything. It's not even an issue of fitting...the flanges just need to mate up, and that's pretty standard.
Old Jun 5, 2006 | 08:23 PM
accident's Avatar
how much quieter will it make it over a straight pipe?
Old Jun 6, 2006 | 06:14 AM
Not much. I had the older style resonated TP that tapered in the middle to ~2.5 inches. When I put on a standard TP the volume increased slightly and was not as deep, but it would be hard for a 3rd party to tell.
Old Jun 6, 2006 | 06:20 AM
Vroompsh's Avatar
i've had both, i agree that the megan pipe sounds a bit deeper, but the test pipe flows better i think
Old Jun 6, 2006 | 06:46 AM
Zeus's Avatar
I'd like to see the flow bench numbers please... that is unless people are just speculating...
Old Jun 6, 2006 | 07:20 AM
anjapower's Avatar
The resonated one definitely sounds deeper and quieter.
As far as flow there shouldn't be much of a difference if the ID is the same throughout.
cla2000
Jul 25, 2016 04:04 AM
yenny
Jul 17, 2013 02:28 PM
Evo_8_REDYG0
May 29, 2013 11:47 PM
Sourav mahmud
Apr 16, 2013 08:46 AM
evoluXrichie
Mar 14, 2009 03:30 AM
