intake manifold
Old Jun 12, 2006 | 03:35 PM
Mr. Boost's Avatar
intake manifold
i am thinking of getting a intake manifold, do u need a full standalone management systems to run it or can u use a utec or something of that nature?
Old Jun 13, 2006 | 04:27 AM
hairy's Avatar
i replaced my stock E8 manifold with a weapon-r intake manifold about 3 mths back. i ran it on the stock ecu and noticed response improved heaps but that was due to it leaning out and when i installed a ralliart PNP ecu the response wasnt as noticeable as the car ECU had sorted out the leaning condition. I have since gone to a stand alone power fc and car runs fine. picked up an extra 35 HP with ecu swap and tune.
the car will run with intake manifold upgrade and stock ecu but i would get a reflash or stand alone to be on the safe side. i picked up aprx 15hp with the intake swap.
Car has a more noticable sound now when acclerating as the walls of the manifold are thin sheet aluminium.
Old Jun 13, 2006 | 10:54 AM
bolsen's Avatar
General rule is if you add more air, you'll need to add more fuel.
A person with a stock turbo will not see the gains from a larger intake mani like a person with a larger aftermarket turbo. This is not to say that you won't see a gain, but there is a very strong argument made by saying you could spend the $$ elsewhere to see a bigger return on your investment.
Old Jun 13, 2006 | 03:31 PM
Mr. Boost's Avatar
well i already have a 50trim from turbo trix, i am just curious if it would work with a car that doesn't have a standalone yet.
Old Jun 13, 2006 | 07:14 PM
hairy's Avatar
mate that 50 trim will get the best out of the manifold. definately get a flash or stand alone though.
Old Jun 13, 2006 | 11:49 PM
mistabones's Avatar
which is better the weapon r or the AMS EVO VIII VSR (Velocity Stack Runner) Intake Manifold?
Old Jun 13, 2006 | 11:58 PM
RenoEvo's Avatar
ams
Old Jun 14, 2006 | 10:11 AM
mistabones's Avatar
i figured it would be.
Old Jun 14, 2006 | 11:06 AM
mxjs's Avatar
Get the Jun or HKS Kansai
Old Jun 14, 2006 | 12:39 PM
mistabones's Avatar
i did not know they had one
Old Jun 14, 2006 | 12:46 PM
Nez136's Avatar
I dont think a lot of these Sheet metal IM have EGR valves which i thought would cause a problem with the stock ecu. Somebody chime in or correct me if im wrong.
Old Jun 14, 2006 | 12:50 PM
thatsMR2u's Avatar
no EGR valve= car running like crap and a constant check engine light
I had buschur port my intake manifold and my throttle body to 65mm and think thats ur best option-- I have my stock intake manifold and throttle body pm me with a price if u want them
Egyptian_b00st
Feb 14, 2017 01:42 PM
RaX
Sep 7, 2015 09:48 PM
bbyevo8u
16
May 16, 2011 08:06 PM
Spinsall4
Nov 27, 2007 09:50 AM
levo2nr
12
May 25, 2006 05:49 AM
