Back to back testing of Invidia, Ebay and Works 02 housings......
Old Jun 28, 2006 | 04:38 PM
  #61
Warrtalon's Avatar
I'm saying it provides no value that warrants a $450 price tag. Why do you need a cast housing when the stocker is cast and can be ported? The huge opening with 3" outlet and removal of the dividing wall doesn't appear to help that much. The stocker is cast, fits perfectly, uses the stock mounting bracket, won't break, looks "stealthy," and costs about $100 to port. The Works housing is the 2nd true cast iron housing in the market behind the stocker and doesn't provide $450 worth of improvement unless I'm missing something.
$450 = GSC cams = 30whp/30wtq
$450 = Custom Dynoflash = 20-30whp/wtq (and you get to keep $75 to use on a fuel pump or MBC)
$500 = alky injection = 30whp/50wtq
$450 = Works o2 housing = 7-10whp
One of these things is not like the other...
Old Jun 28, 2006 | 04:45 PM
  #62
4ringturncoat's Avatar
Be that as it may, when something costs 4.5X as much as the alternative part, then makes LESS POWER, the little features of fitting nicely and looking "stealthy" really go out the window. Those things really aren't valuable when you could port and coat the stock o2 housing and make similar power for less than half the price while retaining all the same things you mentioned. The Works should be maybe $200 at most.
How do you explain wheels then? If that was true we would all be using Enkie RPF-F1's. Just a thought...
Old Jun 28, 2006 | 04:48 PM
  #63
Warrtalon's Avatar
Not sure what you mean, 4ring. Wheels that are expensive usually are extremely lightweight and extremely strong (e.g. forged), which provides a performance benefit. If a set of wheels costs is lighter, provides less rotational mass, looks nice, and costs 1/4 of another set that weighs more, provides less performance, and looks like stock...well, it sounds like a no-brainer to me. I don't think wheels are analagous, though.
Old Jun 28, 2006 | 04:57 PM
  #64
EVOKing8's Avatar
is there a way to weld a bracket on for the ebay housing??
Old Jun 28, 2006 | 05:02 PM
  #65
Spec'd's Avatar
I was wondering the same thing.
Old Jun 28, 2006 | 05:03 PM
  #66
Warrtalon's Avatar
Good question, but the better question is why would you need to if you get the more powerful stock ported manifold instead of a crack-prone, less-powerful aftermarket tubular header?
Old Jun 28, 2006 | 05:08 PM
  #67
Spec'd's Avatar
Are you talking about a ported stock O2 housing ?
Old Jun 28, 2006 | 05:37 PM
  #68
Guerillah's Avatar
I just got my ebay o2 housing in on Monday, got a banging deal at $49.99 + $15 shipping. <3 you ssautochrome. Everyone at my work was amazed that they can sell a piece like this for so cheap.
Old Jun 28, 2006 | 05:41 PM
  #69
dp2580's Avatar
i guess the ebay o2 housing is the one to get?? does anyone know the difference between the megan racing o2 housing and the ebay o2 housing? they look the same to me.
Old Jun 28, 2006 | 05:47 PM
  #70
dsmfan95's Avatar
Will the ebay o2 housing fit the stock lower heat shield?
Old Jun 28, 2006 | 06:02 PM
  #71
RenoEvo's Avatar
^ I dont think so. Can some of you guys with the ebay unit please comment on the durability and strength? Has anyone experienced any failures or malfunctions?
Old Jun 28, 2006 | 06:05 PM
  #72
VTECH8TR's Avatar
Their is no difference between them.
  #73
VTECH8TR's Avatar
No it will not fit.
Old Jun 28, 2006 | 06:06 PM
  #74
badhabit90's Avatar
/\ most people have suffered from severe boost spike installing the ebay O2 housings.
is this true with the Invidia and WORKS pieces?? no one has addressed this issue.
  #75
dsmfan95's Avatar
Originally Posted by VTECH8TR
No it will not fit.
That has made my decision on which housing to get. Thanks
